oscilloscope question
My question is can a standard oscilloscope do the same job as an automotive scope? I cant see why not with the right probe since its simple time vs voltage.
Also what frequency range.. 20mhz scopes especially the old boat anchor types are dirt cheap on ebay.. even older 100mhz are cheap.. I think a digital scope would be an advantage though so one can scroll through time. One can pickup a brand new 70mhz scope for less than $300.
Can anyone direct me on this?
You can pick up a 1 channel DSO called the "U Scope" from AES Wave.com for about $400.00 !!
As an engineer I have used digital scopes and lots of other stuff. There nice but not necessary for my home use as I could not use some of the special features as you would do in an engineering environment. I just want to see if something is there and close to accurate.
I can't compare the automotive scopes as I don’t have enough hands on experience to make a fair comparison. I'm sure there are great for the guys that use them day to day and are dedicated for automotive use.
My only issues is size.. I really dont want a full size crt from the 80's.. was thinking a mid size HP scope.. like the one you probably have.. they can be picked up 2 ch 100mhz for well under $200 on ebay.
Unless someone can tell me what I cannot do with a standard scope that is the route I will go. I realize a 8 ch would be nice but thats about it.. I dont need to see them all at once.
I can see where I will need a current clamp to do some things.. a cyl contribution test would be super cool to have..
" I have Hantek portable scope with AVO meter. It's a regular scope for electronics, there are no special routines or functions for auto-diagnostics and using it requires knowledge about how triggering works and scopes in general. I have lent it to some mechanic friends and they just can't use it. Menus and such could be better and the user interface is a bit frustrating but if you know -how- it's a very decent scope with potential use far outside of the automotive field.
I have never come across the others you mention but from what I have seen online it seems to me something directed towards automotive use with pre-selected triggering settings for "automotive" is much more user friendly and therefore useful for most people"
I can find my way around an oscilloscope.. its pretty simple. Time, voltage and scaling. nothing to it.
I guess the Hantek does not have AC coupling but one can change that with a capacitor in series with the input. Cap chops off all DC..
https://youtu.be/FYunYnX0y_A
I dont need to click on "injector test" to setup an injector test on a scope. I guess if you dont want to learn a little then a icon based system is worth the money.
For that kind of money you can have a modern all in one unit that does much more and you dont have your laptop tethered to it.
The Hantek I mentioned is also a laptop based system but 1/4 the price. Its only 20Mhz frequency (all you need for most automotive unless you want to do logic analysis)..
Rigol and Hantek have very nice digital units that are small and can be used for any home electronics project for will under $300. The Pico STARTS at around $480 I believe. I just dont know why youd want a automotive scope that has many limitations when you can buy a standard scope for less.. so far I cannot find a thing a std scope cannot do except in the case of the 8 channel hantek which is just a luxury to see all 8 cyl at once.. I just dont see why anyone would need that and every single youtube video I see on the unit 2 channels are used.
Actually if you read about the Hantek it can be used for electronic work other than cars.. but it doesnt even have an ac coupler and doesnt go above 20mhz. scopes from the 80's went to 20mhz. Picos similar model goes only to 25mhz and is like I said about $460-$480. also the Pico sampling is extremely poor.. sampling at a maximum of 500MSa/s, here is a Hantek that is 70mhz and 1GSa/s Real Time sample rate. this gives you MUCH more resolution.. you could easily miss something on the Pico.
AND it can be hacked to go to 200mhz (im sure resolution will suffer.
I like an all in one unit because I know I wont use it often and I can put it away and if I need it I can pull it out, turn it on and its all there. I dont have to worry about whatever laptop I have at the time and whether they kept up with the OS releases whether it be Linux, Android or Windows. Just boom, its there at a moments notice. Kinda like that specialty tool you bought and use once every 5 yrs but when you need it you smile from ear to ear.
Sample rate has nothing to do with a super computer it has to do with at what resolution you are seeing the wave form. If you have a small sample rate you are seeing a low resolution average of a wave form and not the entire thing. this can be super critical when looking at injectors. Im not an auto shop, if I were I would want a small rugged scope that has little icons for basic functions. So I get why pros dont want to bother with a std scope.
Not sure whats up with the dude comment. I think I asked a valid question and provided some of my research. Sorry if it offended you.
If you spent $850 on Pico you must have a super high sample rate which is why you are happy with it. Im not spending $850 because Im just a garage hack.
https://www.corvetteforum.com/forums...e-pattern.html
https://www.corvetteforum.com/forums...-patterns.html
