VATS question
Old Dec 11, 2019 | 04:00 PM
mixalive's Avatar
mixalive
Default VATS question
Please excuse my ignorance concerning the VATS system, but I have a question concerning my 92.
I can normally hear when the fuel pump primes my fuel rails at key on. If I had a VATS event (like due to having the wrong key resistance) could I assume I would not hear the fuel pump prime?
Old Dec 11, 2019 | 07:11 PM
SloJo's Avatar
SloJo
If you don't have the correct key I don't think you can ever turn the ignition to the on position.
Old Dec 11, 2019 | 07:12 PM
SloJo's Avatar
SloJo
Old Dec 11, 2019 | 08:01 PM
jazfe's Avatar
jazfe
Per my factory service manual......"the starter circuit and fuel injectors are disabled".
Old Dec 13, 2019 | 04:14 PM
86C4Z51's Avatar
86C4Z51
Yeah it'll crank but no fire.
Old Dec 13, 2019 | 05:42 PM
arbee's Avatar
arbee
No it wont crank. Injectors and starter circuit disabled.
Old Dec 14, 2019 | 07:33 AM
mixalive's Avatar
mixalive
Default Follow up
I understand no crank and injection defeat. But will the fuel pump prime at key on?
Old Dec 14, 2019 | 08:29 PM
aklim's Avatar
aklim
Check it. Use a fuel pressure gauge so you can see if it spikes up like it should and holds. If it is weak, you can see it on the gauge. If you don't see good fuel pressure, check and see if the pump is even being activated.
Old Dec 15, 2019 | 01:31 PM
mykat's Avatar
mykat
Cruising
I'm new to vettes, but I had a 92 Camaro with intermittent VATS malfunctioning. For the Camaro, two modifications needed to be made in order bypass VATS - there is a so called crank disable relay, which needed to be shorted, and a PROM replacement for the ECM with VATS disabled.
Before I got the replacement PROM I was driving around with the crank disable relay shorted. If VATS malfunctioned I could crank the engine but fuel pump would be disabled. Might offer a clue.
To VATS question
