C4 Down!!!
Old Dec 13, 2019 | 04:06 PM
Tim's88's Avatar
Tim's88
2020 Corvette of the Year Finalist (stock)
C4 of Year Winner (stock) 2019
Default C4 Down!!!
Ok. I'm not asking for advice since I'm letting a shop do this one. But I will take guesses of what is may be. I don't know yet. So here's what happened.
Driving home, nothing out of the ordinary, when all of a sudden the car started to shutter and shake. It was loosing power and idling very rough. I pulled over and let it sit running and the RPMs were up and down about 5 seconds per cycle. If I tried to put it in gear it would almost die. I would turn it off and wait for about 5 mins then start again, and it would be worse. Finally, on the last time I turned it on, there was a loud scraping/tapping sound coming from engine on the front drivers side from what I heard. I was thinking timing chain, bad cylinder or something worse. I had it towed back to the house today and tried to start it and it would crank, turn over and run for about 5 seconds, very rough, but then die.
Any ideas. Like I said, I am not working on this one. Just no time. But I was wondering if anyone has experienced this before and could provide some insight.
Thank you,
Tim
Old Dec 18, 2019 | 12:08 PM
Tim's88's Avatar
Tim's88
Thank you,
Tim
Ok, No guesses?? Well, finally found out the issue. 5 of the 8 fuel injectors were clogged... Happened at the same time.
Go figure!
Old Dec 18, 2019 | 12:12 PM
FostersPerformance's Avatar
FostersPerformance
Sound like trash made its way to the injectors for it to happen at once....Id look at the tank and lines to be sure theres not another underling issue. Injectors dont just clog like that. Takes time..
Old Dec 18, 2019 | 12:16 PM
Tim's88's Avatar
Tim's88
That is the nest step... What I'm puzzled at is that I just replaced the fuel filter about 3 weeks ago.
Old Dec 18, 2019 | 12:32 PM
FostersPerformance
Im a boat tech. The main problems weve had over the past 6 or so years is the alcohol attacking and destroying any rubber lines build before then, They will expand, collapse, fall apart internally - all sorts of problems. Then the little black rubber pieces make their way to the injectors, or screens. The alcohol also cleans the hell outta the tank, causing gum and varnish to head to the engine.
I know the vette dosent have much (or any?) rubber lines but still....Will also cause metal lines to rust, and same issue.
People tell me all the time they run super - non ethanol, but in reality you dont know what your buying unless you test it..Kits available everywhere, but its basically a glass tube you put in X amount of fuel and water. Shake it and itll tell you how much is present....Youll be suprised (and prob pissed) at the fuel your buying...
Old Dec 18, 2019 | 09:09 PM
aklim's Avatar
aklim
What injectors do you have?
Old Dec 18, 2019 | 10:34 PM
jv9999's Avatar
jv9999
CEL on? codes?
Old Dec 19, 2019 | 07:17 AM
hcbph's Avatar
hcbph
This brings up a question with 5 clogged injectors - what happened to the fuel filter? If it happened tank side, the filter should have caught it. If not then either the filter is crapped out or it happened post filter. If it's post filter, I'd expect unless the cause was found and fixed it could happen again.
Just some thoughts.
Old Dec 19, 2019 | 07:20 AM
aklim's Avatar
aklim
Just some thoughts.
Good point. Cut apart the filter carefully and investigate
Old Dec 19, 2019 | 09:35 AM
95LT1ZF's Avatar
95LT1ZF
Did you use any sort of pour-in fuel treatment or Seafoam type product right before this happened?
Old Dec 19, 2019 | 09:52 AM
aklim's Avatar
aklim
If he has Multecs, I'd be very careful. If not, he can afford to waste his money on placebo cures for all I care. IIRC, there was a TSB about the snake oils eating the injectors.
Old Dec 19, 2019 | 05:15 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Go figure!
my bs’ometer is tingling.
how did they test your injectors? to discover they are plugged?
only way i know is to remove them and put them on a test machine.
Old Dec 21, 2019 | 06:40 PM
ZWILDZR1's Avatar
ZWILDZR1
They do make a tool that you use by touching the injector and it measures the solenoid clicking on and off. If it is not pulsing correctly or intermittently you can also see that. It has a beeping alarm along with a flashing light. I've seen some techs pull the fuel rail and add power to each injector just long enough to see it spray. Have to be well ventilated and be careful of spark. Marc Haibeck has a page devoted to testing by measuring the OHM's of each injector without pulling the plenum on the LT5. Not hard at all to test the resistance on the L98, LT1, LT4 .
Old Dec 21, 2019 | 06:42 PM
aklim's Avatar
aklim
DVOM can test resistance. Spray patterns need to be tested on a bench. Might as well test the flow volume effectively and accurately then.
Old Dec 22, 2019 | 08:51 AM
don hall's Avatar
don hall
I'm assuming by your forum name that your vette is an '88. If so, that nullifies my guess
that the trouble is a faulty opti. Hope new injectors gets you back on the road......
Old Dec 22, 2019 | 10:00 AM
VikingTrad3r
Oil Producer
yeah ohmi g is the only way but what are the chances so many “went” at the same time. i dont think its right
Old Dec 22, 2019 | 07:08 PM
aklim's Avatar
aklim
A third of a test since it does not give you volume or spray pattern. But yes, you are right. Short of an ECM failure, 5 is hard to swallow. I would ask how they came to the conclusion. As I learned in math, no working, no credit.
To C4 Down!!!
Old Dec 30, 2019 | 09:18 PM
Tim's88's Avatar
Tim's88
First of all, they did pull the injectors. Then they did put them on a tester. But they we visibly clogged. I have pictures.
Old Dec 30, 2019 | 09:21 PM
aklim's Avatar
aklim
Get a reman set from FIC to fix the problem. Also see why it has so much crap in the lines
Old Dec 30, 2019 | 09:23 PM
Tim's88's Avatar
Tim's88
We actually figured out what happened. There was rust in the tank and the fuel pump strainer came off. So it sucked all that junk up. So, we emptied and cleaned tank. Purged the lines and fuel rail, new filter and rebuilt the injectors. Running fine now.
