My wife got me to new visors for Christmas. Any quick way to install them. 96 collectors edition
As always tks pr putz
not sure if they are different from my 87 but simply remove top, unscrew the small plastic trim piece above the visor stem, remove speednut, punch it out, replace.
It doesn't take a real long about an Hour, But before you dive in did your new visors come with the Star clips https://corvetteparts.com/item/clip-...-nut-1984-1996
you can re-use the old ones but you need to pry them off and distort them a bit you can them back if not too bad.
TO do the job remove roof and trims above visors remove lock nut pry off clip drop visors and unplug. Install new ones have someone hold pressure up on visors tap on the clips with small socket, nuts and trims
