My heater core is leaking
Old Dec 28, 2019 | 03:19 PM
wsherrard's Avatar
wsherrard
Default My heater core is leaking
My heater core on my 91 coupe is leaking. Checking the various suppliers I see aluminum replacements and Copper/brass replacements. Anyone have experience in choosing one versus the other? I guess my main concern is not having to do it again for a long time.
Old Dec 28, 2019 | 03:23 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
I've used the aluminum replacements in both my '87 and '86 and have had zero issues. My thought was: "The brass / copper unit crapped out but the original aluminum radiator is still doing fine and looks like new inside" ...so the logical choice to me was to go aluminum.
I vote aluminum.
Old Dec 28, 2019 | 04:41 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Definitely aluminum in my view but really the only way to make sure it lasts is routine coolant maintenence.
Old Dec 28, 2019 | 07:25 PM
wsherrard's Avatar
wsherrard
This one had a blown head gasket for a while that was pressurizing the cooling system. That is all fixed now but I'm thinking this is a side effect of that issue. Anyone partial to a particular brand?
Old Dec 28, 2019 | 08:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
DEWitts may make them. Get the best one you can.
Old Dec 29, 2019 | 01:47 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Whatever type you buy...take it to a radiator shop and have them inspect and pressure test BEFORE you install.
Old Dec 29, 2019 | 02:16 PM
85Vetteman's Avatar
85Vetteman
I have used both with zero issues...
Old Dec 29, 2019 | 07:55 PM
Went's Avatar
Went
Put a copper/brass unit in mine.
Went
Old Dec 29, 2019 | 08:05 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you don't want to change heater cores, change your coolant on a regular basis. Doesn't matter which material you chose...you need to do cooling system maintenance.
Old Dec 30, 2019 | 04:10 AM
1985 Vette's Avatar
1985 Vette
I installed an aluminum HC in my 85 after the original leaked. This was a very time consuming job and some fasteners were very difficult to get to.
You have the later interior so hopefully it is easier for you.
Old Dec 30, 2019 | 07:31 AM
aklim's Avatar
aklim
I don't believe they do.
Old Dec 30, 2019 | 07:35 AM
85Vetteman's Avatar
85Vetteman
If you live in a warm climate, just bypass it..
Old Dec 30, 2019 | 11:06 AM
belairbrian's Avatar
belairbrian
There is nothing hard about doing the later heater cores. Unless you have a hard time accepting that you will need to disassemble the dash. There are no short cuts or tricks. I worked on mine for several evenings after work and got it done. it's just a matter of taking your time and following the steps.
Old Dec 30, 2019 | 11:13 AM
belairbrian
I really don't get this advice. When i bought my 92 it had a bad heater core. Seller had not disclosed it. I found it during the purchase and dropped my offer by $1K.
It's such a common problem that any buyer that has done some reading will know to look for it.
Old Dec 30, 2019 | 11:47 AM
wsherrard's Avatar
wsherrard
I've done the job once before about 18 years ago. i was mostly interested in getting perspective from others about their experiences with Copper/Brass or Aluminum and various manufacturers. I really distrust the Chinese stuff but it seems these days it is really difficult to avoid it. I'm suspecting one of these Chinese Aluminum jobs isn't going to last 18 years but I guess I'm going to get to find out.
Old Dec 30, 2019 | 12:22 PM
aklim's Avatar
aklim
Probably was counting on you having the "Corvette Fever" and overlook a lot of things. Lots of people do so it doesn't hurt to try. Why do you think I always want a PDI by an independent mechanic who isn't caught up in that stupidity to make sure I am not caught up?
Old Dec 30, 2019 | 12:25 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No reason why it shouldn't last 18 years, if you do cooling system maintenance. If you don't want to change heater cores, change your coolant on a regular basis. Doesn't matter which material you chose...or which country the core came from; cooling system maintenance will help you avoid a leaking heater core.
To My heater core is leaking
Old Dec 30, 2019 | 01:42 PM
wsherrard's Avatar
wsherrard
I completely agree that maintenance will get the maximum life out of a system but you seem to be suggesting that there is no difference in quality of any of these products. I could be wrong or maybe I'm misinterpreting what you are saying but I don't agree with the stance that all products are of equal quality.
Old Dec 30, 2019 | 03:04 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'm not implying that at all. While I think ANY heater core is made as absolutely shitty as possible, (and still actually work), there are probably slight differences in quality...brand to brand, unit to unit, even.
I'm implying that:
1. It's doubtful that anyone has changed (and owned) enough heater cores in one car to "measure" the difference in quality
2. The quality is not dependent on the material that it's made of, IMO.
3. If maint were well done, it would be a moot point b/c the factory one would likely last forever and still be working.
4. As long as there isn't a defect, any aftermarket one, brass or aluminum will likely last forever w/good maintenance
5. It really doesn't matter which one you buy too much. It matters more, how it's used and taken care of. If it doesn't come already leaking, it likely never will unless it's allowed to corrode/oxidize.
Old Dec 30, 2019 | 03:14 PM
85Vetteman's Avatar
85Vetteman
If your over 70, you'll be dead before leaks...
