A/C oil question
I have a 1990 Coupe, and my a/c compressor went bad. I ordered a new compressor, condenser and orifice tube, and flushed out the system (so far). The new Denso compressor had oil in it so I drained it. Got to thinking. They must have put mineral oil in it because that was the spec back in 1990. I drained the oil out by rotating the compressor, so now I need to know if I should use 8 oz of ester oil, or 9 oz of 150 pag oil as the 1994 and up vettes use. Also, should I use a/c flush in the compressor to COMPLETELY flush it or is it good enough as drained by hand.
Any advise is greatly appreciated. At over $500 bucks a pop for parts, I'd like the repair to last a while.
A/C Compressor PAG Oil Application Chart
Copyright AA1Car
PAO (Polyalphaolefin) oil can sometimes be used as a substitute for certain PAG oils if the compressor manufacturer approves it.
CAUTION: PAG oils should NEVER be used in hybrid vehicles because it is electrically conductive. POE (polyol ester) oil is usually specified for hybrid cars that have electrically-driven A/C compressors because it is non-conductive. Using the wrong oil may allow current to short circuit back through the A/C compressor, creating a shock hazard.
Mineral oil should only be used in older R-12 A/C compressors because R-12 will not mix with R-134 refrigerant.
"Universal" A/C compressor oils are often PAO-based and are not the same viscosity as the PAG oil recommended for a specific type of compressor. This can lead to poor lubrication and premature compressor failure.
Newer vehicles with R-1234yf A/C systems require a special 1234yf compressor oil specified by the vehicle manufacturer. General Motors recommends GM lubricants only (PAG-PSD1 #19260643 for 2013/14 Cadillac XTS, and PAG-ND12 #19299051 for 2013 Cadillac ATS). Universal compressor oils should NOT be used in R-1234yf applications.
PAG Oil Recommendations for Various Compressors
The following is a list of recommended lubricants by compressor manufacturer. you can identify the compressor mfr. by looking for an ID tag or label on the unit (or see the reference illustrations at the right and left):Compressor Identification
[img]safari-reader://www.aa1car.com/library/compressor_types_2.jpg[/img]. [img]safari-reader://www.aa1car.com/library/compressor_types_1.jpg[/img]Compressor Model and Recommended PAG Oil:
Bosch Axial.........................PAG 100Calsonic CR14.......................PAG 46
Calsonic CWV6.......................PAG 46
Calsonic DKV........................PAG 100
Calsonic V5.........................PAG 150
Calsonic V6.........................PAG 46
Chrysler A590.......................PAG 46
Chrysler C171.......................PAG 46
Chrysler RV2........................PAG 100
Denso 10P...........................PAG 46
Denso 10S...........................PAG 46
Denso 10SRE18.......................PAG ND-8
Denso 2C............................PAG 100
Denso 6C............................PAG 46
Denso 6CA...........................PAG 46
Denso 6E............................PAG 46
Denso 6P............................PAG 46
Denso 6SB...........................PAG 46
Denso 7SB...........................PAG 46
Denso SC08..........................PAG 46
Denso TV............................PAG 100
Ford FS10...........................PAG 46
Ford FS6............................PAG 46
Ford VF2............................PAG 46
GM A6...............................PAG 150
GM HR/HT............................PAG 150
GM R4...............................PAG 150
GM V5...............................PAG 150
GM V7...............................PAG 150
Hadsys HS-090L......................PAG 46
Hadsys RC17.........................PAG 46
Hitachi (all models)................PAG 46
Keihin (all models).................PAG 100
Matsushita (all models).............PAG 46
Mitsubishi (all models).............PAG 46
Nihon DKV...........................PAG 100
Nihon NVR...........................PAG 100
Panasonic (all models)..............PAG 46
Sanden Electric.....................SE-10Y
Sanden SD5..........................PAG 100
Sanden SD7 (key shaft)..............PAG 100
Sanden SD7 (splined shaft)..........PAG 46
Sanden SD7V.........................PAG 46
Sanden TR...........................PAG 46
Sanden TRF..........................PAG 46
Sanden TRS..........................PAG 46
Seiko-Seiki (all models)............PAG 100
Tecumseh (all models)...............PAG 100
Visteon RS-18.......................PAG VC-46
York (all models)...................PAG 100
Zexel DCV...........................PAG 100
Zexel DCW...........................PAG 46
Zexel DKP...........................PAG 100
Zexel DKS...........................PAG 46
Zexel DKV...........................PAG 100
Zexel TM............................PAG 46
Some Vehicle Specific A/C Compressor Lubricant Recommendations:
2000 - 2012 Honda Accord (Denso)....ND Oil 82000 - 2006 Honda Insight...........PAG 46
2005 - 2009 Honda Civic (Sanden)....SP 10 PAG 46
2004 - 2009 Nissan Maxima/Altima....Type S (DH-PS) PAG 46
2001 - 2003 Toyota Prius............PAG 46
2004 - 2012 Toyota Prius............ND Oil 11
1997 - 2012 Toyota Camry............ND Oil 8
A/C Compressor Oil Capacities
If you are replacing a compressor or other A/C system component, it is important to replace any compressor oil that has been lost when parts are changed. The total system oil capacity for many late model passenger car A/C systems is only about 4 ounces (120 ml). A low oil level can starve the compressor for oil and lead to compressor failure.CAUTION: Do NOT overfill the the A/C system with too much compressor oil. Too much oil can hurt cooling performance.
Use the following guidelines for replacing compressor oil when changing A/C components:
Compressor.........1.4 oz
Condenser..........1.0 oz
Evaporator.........1.5 oz
Accumulator........1.0 oz
Hoses..............1.0 oz
The total amount of oil added to compensate for parts that have been replaced should NOT exceed the total oil capacity of the system. If you don't know what the total oil capacity is, check the underhood A/C service decal or look up the information in the OEM service literature.
What About Universal A/C Compressor Oils?
Our advice is this: Why take a chance using a universal oil when you can just as easily use the correct PAG oil?Every compressor manufacturer I've ever interviewed says the same thing: Uuse the specific type of oil specified for their compressor. In most cases, it is some type of PAG oil.
When an engineer designs an A/C compressor, he builds it to certain tolerances that require a specific type of lubricant viscosity, friction charcteristics and wear additives. If an oil is used that does not meet those requirements fairly closely, it might cause wear and friction issues. Eventually, this could cause the compressor to fail.
PAG 46, PAG 100 and PAG 150 oils all have different viscosities, just as 5W-20, 5W-30 and 10W40 motor oils have different viscosities. You should not intermix different viscosities because the viscosity of the mixture may be "out of range" for the appliction for a number of reasons. Thicker oils are typically specified for heavier bearing and seal loads, but also require slightly greater bearing clearances. If a thinner oil is used, it may not provide adequate lubrication. Likewise, an application that specifies a thinner oil to minimize friction and drag may not receive adequate lubrication if a thicker viscosity oil is used.
Because the various PAG oils all have different viscosities, it is virtually IMPOSSIBLE to have a single oil formulation with the same viscosity characteristics as the original PAG 46, PAG 100 or PAG 150. The universal oil will be a compromise blend that fails to meet anyof the OEM specifications. It will be too thick for some applications, and too thin for other applications.
A universal oil may work okay in some compressors, but not others. So why take a chance? A/C compressors are not cheap to replace!
The reason why some people promote universal oils is because it is simplier for auto parts stores and shops to stock a single type of oil instead of a number of different oils.
[img]safari-reader://www.aa1car.com/library/book1.gif[/img]More Air Conditioning Articles:
How To Recharge Your Car's Air ConditionerAlternative Refrigerants
Retrofitting older R-12 A/C systems to R-134a
MACS Recommended A/C Service Procedures (PDF file - requires Adobe Acrobat Reader to view).
A/C Compressor Failures
[img]safari-reader://www.aa1car.com/library/library1.gif[/img]Click Here to See More Automotive Technical Articles
[img]safari-reader://www.aa1car.com/library/yelcar.gif[/img]Be sure to visit our other websites:
Carley Automotive Software
OBD2HELP
Random-Misfire
Scan Tool Help
TROUBLE-CODES
