SuperDamper
Old Jan 22, 2020 | 08:34 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default SuperDamper
I have 2 ATI SuperDampers (6+8 rib) priced to move - $400 each plus shipping. You do not have to have a blower to use. Will fit any LTx Vette (1992 thru 1996). Has keyway for locking to crank - I include key.
Old Jan 23, 2020 | 04:36 AM
grandspt's Avatar
grandspt
z
Are these dampers larger than stock? I just wanted to know if you can wedge it in between the rack and pinion during the installation like the stock damper?
I have an LT4 that I am putting a cam in and wouldn't mind having a good damper on it, I just don't want to lift the engine if possible.
Old Jan 23, 2020 | 07:29 AM
BlowerWorks
Supporting Vendor
OD slightly larger 7.362" - front to back identical.
Old Jan 23, 2020 | 07:31 AM
BlowerWorks
Supporting Vendor
See attached files for installation instructions.
File Type: pdf
File Type: doc
Old Jan 23, 2020 | 04:35 PM
grandspt's Avatar
grandspt
Thank you very much for the information
Old Jan 25, 2020 | 02:13 AM
1993C4LT1's Avatar
1993C4LT1
Not to go off topic. But what are the postives and negatives of installing one of these?
Old Jan 25, 2020 | 01:28 PM
BlowerWorks
Supporting Vendor
1. Keyed - stock LTx not and can slip !!!
2. Superior to stock balancer - see attributes on ATI website.
3. New - your balancer 20+ years old and elastomers shot - good-bye crank !!!!!!
4. Extra 8 ribs for blower should you so choose !
To SuperDamper
