Throttle Body Bypass Fiiting
Old Jan 27, 2020 | 10:20 AM
85Vetteman's Avatar
85Vetteman
Default Throttle Body Bypass Fiiting
Hi Guys,
I'm going to be rebuilding my throttle Body on my 85 and I see they sell the Bypass kit on-line for around $20.00 and I know the connector is two difference sizes. By all the threads I read doesn't state what sizes they are. I hate to spend $20.00 for a fitting and two hose clamps plus tax and shipping when I can over to Ace or Home Depot and get all three for way less. Note: I know not to use a nylon fittings. I'm thinking one size is 5/8" and it looks Like 3/4" but I not 100% sure.
Old Jan 31, 2020 | 10:08 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Waste of money. No performance advantage.
You can make the same parts for pennies.....
Old Feb 1, 2020 | 10:24 AM
vader86's Avatar
vader86
I think those are the right sizes, make it yourself.
Old Feb 1, 2020 | 04:52 PM
85Vetteman's Avatar
85Vetteman
I just did my by pass this morning, simple job, instead of joining the two 5/8" Hoses together with a splice. I decided to run a new hose from the fitting going to the heater it's right near the passenger tire side to the block. It's Impossible to make the bend with the hose without kinking it so I installed a 5/8" hose barb to 1/2" MPT 90 degree Elbow. My issue was turning the elbow a full turn. I needed to remove the temperature sensor and this made it possible to make a turn...
Old Feb 1, 2020 | 04:57 PM
belairbrian's Avatar
belairbrian
I used this one on my 92 5/8 x 1/2
https://www.amazon.com/gp/product/B0195TQQY0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0195TQQY0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
But can't say for sure if all cars have the same hose sizes.
Old Feb 4, 2020 | 05:38 AM
mjlorenson's Avatar
mjlorenson
7th Gear
The water supply to the throttle body helps maintain a consistent temperature for proper fuel atomization under all operating conditions. Sometimes it actually cools the throttle body, while sometimes it brings the TB up to proper temp. For a race engine, you can ditch it. For a street engine, I'd leave it in place.
Old Feb 4, 2020 | 10:19 AM
ctmccloskey's Avatar
ctmccloskey
I agree with mjlorenson on this issue.
I have had carburetor ice and sat on the side of the road while it melted and that is not fun. I have also experienced carburetor ice while flying and that is scary.
Anything that helps the atomization of the fuel is helpful and good for the engine. The Engineers at GM did not do this accidentally, it was very intentional and therefor they must have had a reason. They guys at GM wanted to make all the horsepower they could (reliably) for the Corvette and if they deemed it necessary to have a heated throttle body that is good enough for me.
By the way, Welcome to the Corvette Forum mjlorenson!
Old Feb 4, 2020 | 11:15 AM
RetroGuy's Avatar
RetroGuy
I've also performed this simple T.B. Coolant Bypass mod. I knew I didn't need any extra heat in my TB since I live in moderate So Calif climate. The other advantage with this mod is not having any coolant drip over the engine and maybe on your Opti when removing the TB in the future.
Old Feb 4, 2020 | 11:31 AM
TommyFox's Avatar
TommyFox
Can't really compare this with a carb. Back in the day many did this and never had a problem with the car in 0* degree weather. Once the car is started the under hood temps are going to heat the throttle body any way ,these c4 hoods hold in the heat. Going from memory I think there was a 3 or 4 hp gain doing the bypass cutting a 200* coolant from heating the throttle body in a warm weather climate. So in other words , take it or leave it. I bypassed all of mine for the less chance of a coolant line failing. In a warm weather climate it's going to add heat not cool it.
Old Feb 4, 2020 | 11:42 AM
vetteLT193's Avatar
vetteLT193
It never cools it and colder air is always better going into the engine. GM put it there because the engine was designed to be used in all extremes... however, hardly anyone drives these things in extreme cold anyway. It's been tried and tested over and over... unless you are driving in extreme cold (sub zero) there is no worry and it adds a few HP for a few bucks.
Old Feb 5, 2020 | 10:29 AM
RetroGuy's Avatar
RetroGuy
AND everyone wants more power...
Old Feb 5, 2020 | 02:34 PM
mjlorenson's Avatar
mjlorenson
7th Gear
Thanks for the welcome, ctmcloskey! Great to be here. Just bought an '88 manual Z52 coupe, loving it so far.
To Throttle Body Bypass Fiiting
