stock sbc block hp limits
. Didnt expect that one. Firstly want to thank everyone for all the useful information. But technical specs aside let me share a testimonial here. My generation is much to brazien about their opinions on cars and often misinformed. And one of the biggest things I LOATH about new gen GM fans is that the new camaro, corvette, and sleeper truck guys (speaking of my gen only) have pretty much 0 respect for the SBC and LT-1. And all i ever hear at my local car meets is testosterone wars between that 1 poor guy who just bought an SBC car vs all the c5 and c6 owners, (that and the mustang and LS swapped guys practically holding court against each other...) i feel, with all technical specs aside, that there is a divide between old school and new school GM because of this and I dont feel that should be the case. The Camaro and Corvette represent a heritage of Multiple decades, standing through economy crashes, fuel crisises, and near cancellation by corporate in some cases. And i've done my damndest thusfar to try and get people to understand that if we're gonna pick a fight with anyone. It should be the 302s, 351s, and 5.0's on the strip and track as is the age old rivalry. Not this infighting nonsense. I hope 1 thing we all can agree on in this thread is that GM is GM.My Nova originally had a 350 in it. Then a 396, then a 427, then a 468. Bigger and meaner every iteration.
The 468 ended up around 650 HP because I wanted to keep it mild. It was still hydraulic cam, 850 double pumper, 10.5:1 compression, and ran just fine on 93.
I put a little spray on it at one point to get more some power out of it.
I decided to go ahead with the LS swap when the big block got to the point where it was more maintenance than it was worth.
I picked up an aluminum 5.3 from the junkyard along with a 4L80e, tossed in a very very mild cam, put $1800 in a single turbo setup,
It made about 200 HP more than the big block made on nitrous, got 14/24 mpg city/highway beating on it hard, fired up first crank,
and even with a 4" fender dump downpipe, was quieter than the big block was with a pair of flowmasters. There was no looking back...
That said, I think trying to LS swap clean original cars is a tradegy. You're loosing something when you do it.
If you have an old beater and want to go stupid fast for super cheap? Do it. Have a heavily modded chassis and want to make a fast street car? Do it.
Have a clean original car with that old small block sound? You have something special, don't ruin it.
with SBC production blocks there is alot of variation in them. 010 which can vary by weight and composition. I have known particularly hard blocks that machine shops never wanted to see again. One the damage in a crash, it's replacement was 20 lbs lighter. It was a big deal for stock car that was now under weight. Supposedly a 010 block with 020 020 behind timing cover and nodular iron 2482 caps was the best block. GM introduced the "bowtie" block in the early 80's because of the lack of QA of production SBC blocks.
Modern stand-alone ECUs and careful setup planning go a LONG way. The local no-prep guys are a big group of 4-second 1/8 cars that do weekend street races for big money, ALL with turbo LS engines, Holley/Megasquirt ECUs, and DOT legal radials.
In the 60's and early 70's (during the HP wars) the 4 Bolt Blocks were actually pretty beefy. But as we got into the late 70's and 80's the factory motors were not making any real power and the factory engineers were worrying about fuel economy and cost - so metal was removed from the Blocks. I've heard the weight differential can be close to 40 Lbs.
Spencer - I believe the Dart SHP is "rated" to around 700 HP - but why don't you give the folks at Dart a call and discuss it with them. The BIG advantages of the aftermarket block is that the designers were free to put the metal where it is needed, they use a better grade of cast iron than the factory does, and they do the majority of the machining in FAR fewer operations - meaning that there are less tolerance "Stacks" to worry about. I Personally, see almost NO reason to go with a factory block on any SBC application where the expected power level is in the 500 range or above, it just doesn't make any sense.... But don't take my word for it - take some time and talk to engine builders who have a reputation for engines that stay together - they work with this stuff all day long - see what they say...
Once I'm moving, every bit of the available power gets tapered in, but I can still launch hard enough to outrun anything else, bikes included
In this video they explain how you can control wheel speed. I assume that you are doing something similar.
Several years now on the current combo. 16+psi boost, 100 shot of nitrous, slinging it to 6800rpm.
Big heads, big cam, carbureted blow-through centrifugal setup.
FWIW - 90% is in the tune.
130 in the 1/4, 158 in the half, 188 in the mile.
If that's not a testament to the durability of a 2 bolt sbe sbc, I dont know what is.
Aggressive timing, conservative AFR, low EGT's, and a loose nut behind the wheel. That's what my old car seems to want.
Also, Engine Masters took a basic "rebuilder" Vortec 350 and tried to blow it up w/boost. They hit 765hp/695tq and the thing never faltered. They gave up.
That is another testament.
While I have zero doubt that what you said is true - I've also seen a GM Crate engine with 3 pistons installed incorrectly (upside down) that was blowing coolant out the exhaust from a failed head gasket - in less than 1,000 miles of use. MUCH depends on the actual parts that are installed, and how carefully they were assembled. (I have also heard that many stories about the crap people would find when they tore down stock motors built in the 1970's & 1980's.)
Just remember - in the production world - keeping costs down is probably the highest priority. A good set of aftermarket rod bolts costs about $100. If a rod bolt fails - it's common for it to take out the block, the crank, and sometimes the heads. To me - if I've spent some money on the heads - that is too much of a risk.... Others have different opinions, and are more than welcome to do as they see fit. THAT freedom to do as you choose is what makes this a Great Country !!!!
That is the damned if you do / damned if you don't part. Rod bolts, machine shop reworked rods, same junk cast pistons, new rings, hone the block, put it all back together to still have a crap cast crank and crap cast pistons in a 2 bolt block.
This is why there are guys like me who started with a stock motor, then grew to where it is now on a budget - "the wrong way".
I can vouch for the stock block making somewhere in the 700ish range - for me - reliably - aside from head gaskets with stock head bolts.
Is it the right thing to do? Hell no. Was it in my budget to build a sub $7,000 car that whoops up on cars 10x the price? Hell yes.
One day I will wipe out the crank, melt down a couple of pistons, push another head gasket, or otherwise destroy the motor. I'm ready. I have a cage, engine diaper, and fire suppression.
When that day comes, I'll likely build a "proper" motor with an aftermarket block designed to hold 1,000hp+ and good components.
2 bolt BB are super stout
I imagine if you twist them long enough something will go esp if the stroke gets bigger that will push limits
Most cars can get by fine wtih a 2 bolt main cast crank etc. If youre worried get a basic forged piston and better rod bolts
I honestly think you'd have a very hard time finding any V8 that couldn't make that much power just winging it on the engine dyno. Through a stalled auto, that is only ~500whp after all.
Cheap fun.
We're in agreement !!! (Although I do remember some "Hot Rod" articles in the 1980's where they would change the rod bolts and not resize the rods, and I believe they normally got away with it. In my world - things don't normally work out that way...
Last time I built a motor - I started with a $5K budget and ended up spending $10K. Every single thing l did led to "just one more upgrade".
