Wheel fitment.
Old Feb 12, 2020 | 09:41 PM
Chance clark's Avatar
Chance clark
2nd Gear
Default Wheel fitment.
Hi. I'm shopping for wheels for my 85 vette. I found some I like but they are 5x120 and I was wondering if I can run them since our pattern is 5x120.65. Thanks in advanced.
Old Feb 13, 2020 | 09:34 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I know some people do use the wrong bolt pattern, but I would not recommend it.
Although the bolt pattern is "close", it can cause stress on the bolts, and depending on tightening can leave the wheel slightly off center causing vibrations, etc.
I would not do it.
Old Feb 13, 2020 | 11:11 AM
c4cruiser's Avatar
c4cruiser
I would not do it.
The 120mm bolt pattern is for cars like BMW and possibly Mercedes. While that .65mm difference doesn't seem like a lot., it's not the correct bolt pattern. DON'T use it!!
Old Feb 13, 2020 | 01:46 PM
MatthewMiller's Avatar
MatthewMiller
FWIW, you will have a lot more options in the correct bolt pattern if you search for wheels with more offset and then use spacers to make up the difference. For example, the 16x9.5 wheels on your car have 38mm offset (IIRC). You will find a lot more 17x9.5 and 18x9.5 (or wider - whatever you're looking for) with offsets around 56mm, like the later C4s had. So that's 18mm more offset, and you would just use a 18mm (or 3/4") spacer to put the new wheel back in the correct location.
Old Feb 13, 2020 | 05:25 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by c4cruiser
While that .65mm difference doesn't seem like a lot, it's not the correct bolt pattern. DON'T use it!!
If you decide to use them, you'll need to be sure you tighten the SAME LUG NUT FIRST every time. Since the lug nuts are tapered, that first lug nut will be centered on that stud. Otherwise, different lug nuts will be slightly off-center, so your wheel balance will change every time you mount your wheels!
To Wheel fitment.
