Considering a C4, LS Swap?
I am currently looking at an 84 that has the crossfire engine pulled out, that being said I'm trying to gather opinions on what I should do. Ultimately my goal is to get a C4 up and running quickly and with a tight budget as I am a college student currently doing an internship. I'm not looking to make much power, just a reliable daily that can be fun to drive on the mountain roads by my uni. The original engines that these cars were equipped with are in short supply so I am also considering an iron block LS swap, if I do go this route I'll probably do a basic build of a cam, gen 4 internals, and all the supporting mods, my power limiters being the A4 and the Dana 36 in the back. I'm going to list a few questions.
What is a realistic time frame for a swap like this assuming the engine is built and the harness is ready?
I know the big things I would need to do are the mounts, cooling system, accessory drive, and notching the K-member, I'm not too worried about the harness as that's basically what my internship is.
Would I maintain DIC functionality, or is that done away with?
I know that you can get the dash to work with a P01/P59 PCM but I haven't seen too many mentions of if the DIC also still works.
Will ABS and other features of that nature be an issue with the swap?
This is a big one for me, as much as I hate the extra weight and complexity, the roads are a dangerous place once they get wet and I'd like the peace of mind of knowing ABS will still work.
Will the 84 suspension cause issues in the front with the weight of an iron block LS?
I know the 84s had a super stiff suspension from the factory, I'm ok with a stiff ride, but I also drive 4 hours between home and college, some of the roads can get pretty rough.
All in all, I'm pretty sure my next car will be a C4, I'm just trying to figure out what is right for me.
A4 and Dana 36 are perfectly fine.
Not 100% on DIC functionality. I think you can have nearly all of it, but there will be some things missing.
I believe the ABS is stand alone on the 84 and unaffected. Someone else can correct me if I'm wrong, I'm not 100% clued in on all of the differences of the C4 through the years.
I'm not sure why you think the C4 will have issues with the weight of an iron block LS when the stock 84 engine was all-iron.
DIC will work except for MPG read outs... who cares.
Iron block LS is all of 5lbs or so heavier... again who cares. The biggest thing would be some of the 84 specific things but even still... as easy as any other LS swap... if it is a real 84 hood though, save it because I don't think it'll clear without cutting. (The cold air ducting beneath I think would hit the valve cover as it is a bit wider... could be remembering wrong. Only seen 1 c4 with a LS swap. Hard to picture dimensions without having both on a stand but the 84 hood is pretty interesting underneath.
You said you want ABS so maybe an 84 isn’t the best option if that’s a must. The only safety feature on an 84 is a pillow on the dashboard for the passenger to hit their head on. If you learn to modulate the brake pedal ABS is not required but it takes a bit of practice.
you can reach more power than you will feel comfortable with on an sbc
afr makes 195 eliminator heads that flow ls3 numbers to negate any advantages the ls3 may have over the sbc
I only have $2500 in my entire engine/turbo setup.
So unless those heads are going to bolt on 200 HP, I'd say they aren't doing you any good for the amount of money spent.
Or you can spend $2300 on heads and still not have an engine. Weigh your options.
Also, the afr 195s are great but the engine will likely need to be stroked to 383 to get to cammed 6.0/6.2 power #s and then they still fall a little short. The afr 195s have great flow numbers but not a lot of .600+ lift cams being slapped in gen 1/2 blocks to take advantage of the flow. Then you will need to figure out the intake manifold issue as the stock c4 stuff isn't going to work well and mini rams and other intakes that might fit are expensive.
I didn't realize that the 84s didn't have ABS, ABS isn't a requirement but it's a nice to have. How are the brakes biased on the 84s? I've read they're anywhere 80-20 to 60-40, I was assuming that 80-20.
As much as I'd like to swap in an LS3 those engines are going for around $3500 around here, where an LQ4 is about $300 complete. I'm trying to keep this college student budget friendly and basically just get this car on the road. My way of thought is get it driving and then every couple of months do some mods, keep it mostly bolt on friendly if possible.
No notched K-member? Is that with a specific accesory drive or does the LS just drop in?
It does have the CAI hood, but rather than eliminating that I think I'm going to 3D scan it and see if I can CAD up an intake that works with the LS and doesn't completely butcher the hood. I've got a good amount of experience with carbon fiber layups so hopefully I can get it too look half decent.
I hadn't considered the headers, I can get a set of C5 headers for pretty cheap and welding them up to change collector angle doesn't sound too bad, again, I'm looking to get this car in the road sooner rather than later, and if that means I end up pulling the engine in 6 months to get some real power I'm ok with it.
My basic package was an LS-1 build along with a 4L65e automatic transmission from Turnkey Engine Supply of Oceanside, CA. They provided a kit of sorts that included the engine, motor mounts (which had to be shimmed), wiring harness, Howell computer, shorty headers, all accessories with a serpentine mount including a/c compressor. I also opted for their premium package which included "big block" chrome coil pack covers, a hydro-dipped manifold and trim for the power steering reservoir.
I retained Corvette Masters of Maitland, FL to do the conversion for me. It took a lot of time, but there was a lot of work to do. Given the larger transmission, the cross-frame had to be notched and reinforced. And the longer length of the transmission including the tailshaft housing caused us to consider either shortening the driveshaft (which we didn't do) or reusing the original transmission's tail-shaft housing (which did fit.) We also found out that the early C4's had the engine and transmission custom fit during installation resulting in several millimeters of misalignment when the new transmission was mated to the included transmission adapter and the engine. That required about a 90 day delay as we sought out a machine shop to build a jig and machine the interface so it was correct.
The entire front end of the engine compartment was reworked to accommodate the swap. I purchased a new cross-flow radiator from Ecklers. A visit to Coastal Corvette (used Corvette parts) resulted in a top end radiator mount and air intake system from a '96; we reused the bottom end radiator mount from my original. A new fan box was fabricated by Corvette Masters containing two Spraul electric fans.
Lots of engineering by Corvette Masters went into making the installation look like GM had designed it that way. Cudos to Robby Hooper and his team.
The generic Howell computer came with some standard settings that were not proper for my installation. It was enough to get the C4 started and on the road, but terrible for the actual swap. I took it over to Faster Proms in Lutz, FL for a street tune by Jeremy Formato. Perfection!
Here's a video of the initial startup: https://photos.app.goo.gl/pBLWTz6Aam7UjkBQ6
And one of many shots of the completed installation
LS-1 in 1984 C4
So, yes, you can do a swap yourself in a "reasonable" period of time. My decision to go the resto-mod route has resulted in recognition from several national magazines including a 3 page article in Corvette Magazine, appearance in Vette Magazine, and 3 page article in Classic Corvettes magazine (Eckler's house publication.)
LS-1 in 1984 C4
LS-1 in 1984 C4
what kind of misalignment were you seeing, was it lateral or torsional? I'm not too sure how I'd combat that level of misalignment but I'm sure I could figure something out if need be. Was the rad the majority of the front end work, or were there other aspects that needed to be changed to get the engine to fit.
Here you can see the offset of the shaft in the housing with the bolts in place, but the yoke not installed.
Here the yoke is placed over the shaft and you can see the small gap at the bottom of the housing.
With the bolts tightened loosely, the shaft cannot move. Thus the machining required to get a good mate.
Also the hood scissor support was removed from the right side and a piston rod support installed on the left to free up space for the a/c compressor. It was necessary to cut a rectangular opening in the fender wall for clearance of that unit.
The stock a/c dryer had the openings in the wrong place for the rerouted a/c lines, so one for a Camero fit properly and new lines manufactured for it.
I forgot to mention in the original post that a low profile oil pan was required and obtained.
I'm sure there were other adaptations made that I may have missed. I've got a ton of pictures as the install progressed, but am not sure what all of them are showing...
