Issue Installing Crank Hub
Old Feb 29, 2020 | 02:12 AM
az_camaro's Avatar
az_camaro
Default Issue Installing Crank Hub
Long story short: I had the motor in my 92' LT1 rebuilt at a engine rebuilding shop. The crankshaft hub needed to be put back on - Looking through the parts I had, didn't find it so I bought one off eBay. Apparently there are 2 that could be for the motor & I got the wrong one & had to have it cut off.
I got another hub from a local wrecking yard. The shaft was noticeably shorter. Same result, Even tried to get it pressed on using this hydraulic jaws of life tool. What am I doing wrong? This one is from a 93' or 94' motor which I researched to be sure I got the correct one.
A lot of threads regarding trouble with the removal of the hub - not installing
BTW: Shouldn't the shop have put it back on?
Old Feb 29, 2020 | 05:39 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Proper way would be to use the Kent Moore J 39046 tool, or you can make a hub installation tool.
https://www.corvetteforum.com/forums...installer.html
Old Feb 29, 2020 | 09:42 AM
Kevova's Avatar
Kevova
The 92 -95 are the same. The 96-97 are shorter because of the crank sensor interupter, required for OBD2. Hub fit seems to vary from : "Oh, that was easy to its never coming off". Using the correct puller is important. The pulley holes are not symmetrical. A light lubrication can aid in R&R
To Issue Installing Crank Hub
