MiniRam FPR replacement
Old Mar 16, 2020 | 01:35 PM
Gareth's Avatar
Gareth
Default MiniRam FPR replacement
Hi all,
I have a miniram 1 that I got 2nd hand and came with the FPR all ready attached. I have a lot of symptoms that are in common with a faulty FPR so I want to replace it. I could just get a replacement from TPiS but now the car is a 427 with 44lb injectors I am wondering if actually i should have something more up spec? What would people recommend?
If so, the FPR is directly mounted on the return fuel rail so would one bung it with a weld on -6an fitting?
Many thanks in advance
Old Mar 22, 2020 | 01:36 PM
89gta383's Avatar
89gta383
Do a search, that fuel rail has limitations above 550 hp as the rail has a restriction inside. You could get rid of the crossover tube and run a y off the back also like I did. TPIS did my mods for $150
