raditor hoses LT4
Old Nov 23, 2002 | 08:59 PM
larryfs's Avatar
larryfs
Default raditor hoses LT4
something so simple, yet has become a major hassle. I can't get an upper and lower hose.
pepboys don't list em, for the 96 and probably any vette for that matter.
autobarn only listed the upper, and eventually ordered a GATES upper and lower hose.. 2 weeks ago. hasn't come in yet, and they want $8 in shipping !!
I don't feel like driving 10 miles to autozone. but I may have too..
any mail order company have decent name brand hoses?
just thought of it, I should have ordered through Dal, but usually go local on something that should be so standard !!
Larry
Old Nov 23, 2002 | 10:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: raditor hoses LT4 (larryfs)
Call Jeff Kopp and tell him you are from the Corvette Forum, he will hook you up.
800-728-8267
Old Nov 24, 2002 | 10:18 AM
No Go's Avatar
No Go
I agree.
Got mine from Jeff Kopp for 8 and 14 bucks each plus 6 for shipping. Had them next day.
He is the place for factory replacement parts-that are OEM!
Old Nov 24, 2002 | 06:01 PM
Topload's Avatar
Topload
You've most likely read this enough but I had to add my $.02......Jeff Kopp is da man. I just finished replacing the radiator, upper & lower hoses plus a bunch of odd ball small parts. Called Jeff and he filled my order by phone - had everything two days later. The guy is a master when it comes to knowing what part numbers are the correct replacements for OEM stuff on Vettes. I don't even look anywhere else - just give Jeff a call and quit worrying about where I might have to hunt to find the right parts. It's just to easy.....and he's the most friendly parts guy I've ever dealt with...........
:seeya
Old Nov 24, 2002 | 06:13 PM
larryfs's Avatar
larryfs
Default Re: raditor hoses LT4 (Topload)
are there any other hoses that I should replace besides the raditor hoses?
ie: any easy heater hoses that are readily available??
thanks
Old Nov 24, 2002 | 06:37 PM
Topload's Avatar
Topload
Heater hoses are accessible under the surge tank and don't look to be to tough to get to - I only replaced the hoses to the front of the engine because they felt soft and looked a little pregnant. I didn't replace any other hoses - I had plenty to do with the radiator, opti and water pump swap this weekend......a bit more of a bite than I had expected. Good luck with your repair.
:yesnod:
To raditor hoses LT4
