crate engines
Old Nov 24, 2002 | 10:55 AM
jtfrog's Avatar
jtfrog
Default crate engines
Does anyone know where to get a crate engine for an 1986. I have an early 86 with cast heads. Would like to know part numbers for stock and for performance engines and where to look online. I know i am asking alot.
Old Nov 24, 2002 | 11:14 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: crate engines (jtfrog)
i aad purchased some stuff from Scoggin/Dickey Performance Chevrolet in Lubock Texas a while back, if memory serves they had crate engines :cheers:
Old Nov 24, 2002 | 12:11 PM
vader86's Avatar
vader86
Yeah a Scoggin Dickey catalog is your best bet for a crate motor.
a ZZ4 is a direct replacement, with better heads, although it does have a different cam and is carburated and you will have to switch over your cam if you dont want a reprogrammed chip and you have to switch over your intake to retain EFI
Old Nov 24, 2002 | 12:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: crate engines (vader86)
http://www.sdpc2000.com
http://www.paceparts.com
Old Nov 24, 2002 | 08:10 PM
trupp's Avatar
trupp
I swapped a ZZ4 into my 85 this summer. Everything went great. Had to modify the crossmember so the dampner fit but that was not to difficult. The TPI bolted on just fine and so far the stock computer is working fine. ie. no codes or check engine light. I know there is chip in my future but the stock is causing no problems. This setup passed Texas emission tests. I bought the engine from Go Autocenter in Dallas, they had the best price I could find on the net. http://www.goautocenter.com/
Old Nov 24, 2002 | 08:24 PM
gtsyellow's Avatar
gtsyellow
Default Re: crate engines (trupp)
the vortech crate engines are also a great deal if you don't mind the weight, all you need is a scoggin doggy lower manifold to be a direct swap. my only argument with the zz4 these days is how darn expensive it is. you can build a real clearanced, balanced & just generally nasty 350 for bairly more than what they cost.
To crate engines
