Reusing knock sensors... thread sealer?
Old May 6, 2020 | 02:07 PM
jmgtp's Avatar
jmgtp
Default Reusing knock sensors... thread sealer?
Use thread sealer or not?
Original sealer seems a bit worn after pulling them out. Will a dab of thread sealer impact the sensors function?
Should it matter...94 LT1
Old May 6, 2020 | 03:43 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i use a dab of thread sealer. always been fine.
Old May 6, 2020 | 06:52 PM
DGXR's Avatar
DGXR
I used copper anti-seize on my knock sensor threads, torqued properly and no leaks. I understand they need a good ground to work properly -- sealant may interfere, or may not based on VT's reply.
Old May 6, 2020 | 08:18 PM
jmgtp's Avatar
jmgtp
Thanks for the replies, I ended up installing them with a little thread sealer. I thought of the need to keep a good ground so I kept the sealer to the 2nd half of the threads on the knock sensors, this way the threads at the front stayed clean and keep a good ground. Torqued to 14lb ft.
To Reusing knock sensors... thread sealer?
