Does anyone have a list of the ranges that I should see when using the TPRT program. Like the O2, MAT, MAF. I know the TPS is 0.56 to almost 5.o volts.
I had an 84 4 plus 3 and I got the OD to work and the ran pretty good. I ported the intake and picked up some extra HP. At 75 miles an hour it got 27 mpg. I think the 4 plus 3 is much mi lined unnecessarily. Thank you and have a great day
You're correct. Lots of bad information and negative opinions from people here who've never owned one or driven one. Learn to listen to owners with real knowledge about them. One member here called "ihatebarkingdogs" has an educated and lengthy true knowledge on these transmissions. Give him a shout.
Do you already have scan data? Post a log if you can.
With only 25 bytes at 160 baud, you're not going to see much, but it is better than nothing.
Keep an eye on the BLM to ensure that you have plenty of working range between the 108 and 160 limits under various driving conditions. 128 +/- 10 is considered to be good, but really anything in the working range is fine. If you're fine tuning, many like to see something slightly rich like 120-128, but this is largely academic.
I did not get notification of your post. I would have replied sooner, sorry. I am using TunerPro RT from Mark Mauser. It's actually a really nice program. I am going to run it again this week. The car is at a shop. I will write down the values. yhe O2 is running about 140. But, I can smell the car is running rich. I think the FP regulator is set too high. I will look at the BLM. Thank you
I did not know until recently the 85 has forged crank and rods. Some of the 86 do but that is it. Everything else is cast. But, for me being I do not run high revs it's kind of academic.
