Mirror adjustment problem
Old Nov 24, 2002 | 10:56 PM
darkredlt1's Avatar
darkredlt1
Default Mirror adjustment problem
My passenger side mirror will move left and right, but not up and down. The left side is working. Where do I need to start looking?
Old Nov 25, 2002 | 07:16 PM
greg84's Avatar
greg84
Default Re: Mirror adjustment problem (darkredlt1)
hi,had the same promblem on my 84 and it was the motor in the mirror assmly.good luck greg84 :cool:
Old Nov 26, 2002 | 09:39 AM
PTz-92-LT1's Avatar
PTz-92-LT1
If you drivers side goes up and down that means it probably is not the switch, rather the motor. Although this is not directly addressing you problem the following link will show you how to remove the mirror and motor.
http://forums.corvetteforum.com/zerothread?id=440667
To Mirror adjustment problem
