trouble code 34
Old May 16, 2020 | 07:00 PM
blkvette85's Avatar
blkvette85
Default trouble code 34
I just replaced the engine in my 87 vette. Replaced the complete exhaust, new injectors, gaskets ..etc.
the car runs rough, and has a code 34. I went through the factory manual and everything checks out. Checked all the vacuum lines everything is connected. replaced all the intake gaskets. Let it run for a while and the front exhaust pipe started glowing red hot. I have since replaced the cat. I have swapped the mass air flow sensors with one for my 85 and no change.
any idea what could be causing a code 34?
thanks
Old May 16, 2020 | 08:56 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by blkvette85
I just replaced the engine in my 87 vette.....the car runs rough, and has a code 34.......Let it run for a while and the front exhaust pipe started glowing red hot. I have since replaced the cat. I have swapped the mass air flow sensors with one for my 85 and no change.......any idea what could be causing a code 34?
Have you double checked your timing? The glowing exhaust makes me think that your timing is pretty retarded.. During your rebuild you could have easily "skipped a tooth" putting the distributor back in.
Old May 17, 2020 | 11:26 AM
KyleF's Avatar
KyleF
Timing or leak.
Trouble Code 34 indicates that the Mass Air Flow (MAF) sensor is reporting less air is entering the engine than makes sense based on RPM and TPS. I would think either your TPS voltage is not correct or you are getting air into the engine the MAF is not seeing. Especially since you swapped MAFs. What RPM are you seeing while it runs? A really lean condition can cause glowing manifolds. What 02 readings are you seeing?
Timing could be off enough that is it firing late and you are getting fuel burning in the manifolds. This should be easy enough to check.
Old May 18, 2020 | 05:30 AM
blkvette85's Avatar
blkvette85
thanks. I’m thinking timing is the issue. I double check it.
Old May 18, 2020 | 03:32 PM
blkvette85's Avatar
blkvette85
Originally Posted by ihatebarkingdogs
85 and 87 MAF sensors are different electrically and not interchangeable.
I did not know that. I double checked and you are correct. Thanks. Looks like I’ll be getting a mass airflow sensor.
To trouble code 34
