Headlight problem 1985 c4
Old May 17, 2020 | 05:37 PM
Matthew Moore's Avatar
Matthew Moore
2nd Gear
Default Headlight problem 1985 c4
when I go to turn on the headlights only the passenger side goes up but then it doesn’t go down. Driver side headlight doesn’t move at all. I assume I need a new motor for the drivers side and maybe a new relay? I’m not really sure.
Old May 17, 2020 | 07:34 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The first thing you need to know is that the '84-'87 headlight motors are entirely different than the '88 '96 headlight motors. If you get advice from anyone, verify they're talking about the '84-'87 motors. Many people are confused by this issue.
Try this link to a thread in this Forum with similar problems: (Note that some are confused. There are no "pellets" in the early headlight motors.)
https://www.corvetteforum.com/forums...post1563680285
Welcome to the Forum!
