Compression test prep
Old May 19, 2020 | 02:01 PM
JD1964's Avatar
JD1964
Default Compression test prep
I will be doing a compression test on a 94 LT1. I’ll remove all spark plugs and make sure the battery is juiced up good. If I pull the pcm fuse, will that disable the ignition coil and injector pulse during the cranking process?
thanks
Old May 19, 2020 | 03:26 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Be sure to block the throttle at least half way open during the test.
Old May 19, 2020 | 03:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
thanks
probably. There shoudl be injector fuses too. Also, if you disconnect the opti harness, you won't get any spark or inj pules.
Old May 19, 2020 | 08:45 PM
JD1964's Avatar
JD1964
6-155 5-150
4-155 3-155
2-160 1-150
Here are the test results. It’s a 125k mile engine. So, how are we looking here? All in reasonable range of each other, that’s for sure. Is 155psi average cranking compression indicate a healthy LT1?
Old May 19, 2020 | 11:26 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Look good to me.
Old May 20, 2020 | 07:00 AM
JD1964's Avatar
JD1964
On a 94 LT1, anyone know if the factory installed spark plugs were AC 41-906 iridium? And would these have a date code? The ones I took out have “Made in USA“ then numbers either 08 or 10.
Im wondering is those numbers indicate the year of manufacturer ie, 2008 and 2010. I’m trying to determine if these had ever been replaced.
Old May 20, 2020 | 02:56 PM
84 4+3's Avatar
84 4+3
I don't know about the plugs but the compression seems good. I look more for how even each cylinder is vs what the actual number is. Granted if they're all 80 you have a problem too but its an even one lol.
To Compression test prep
