CNC Cylinder Heads feed back please
The cam is from Cam Motion. The last contact info I had on them was:
Cam Motion
292 Dallas Dr.
Baton Rouge, LA 70806
(225) 926-6110
The grind is # X2221-2271-13
This cam was developed for Tommy Morrison for the Corvette Challenge Series. It is just slightly more aggressive than the ZZ-X cam.
The cam specs are:
225/229@ .50 w/.555"/.556" lift w/1.6 RR's.
Lobe separation is 113 deg. and the lobe centers are at 109 deg.
Vic:
NO additional numbers yet. Like I said, I've only had it to the strip once. I'm putting everything back together, and I'm investing in some MT's or DR's to get some traction of the line. We'll see what I can get with some traction. I'm sure I'll just barely dip into the 11's with this setup, but only time will tell.
Since moving to Florida last March, I managed to get it to the track and had the good fortune of running against Hutch's GS (we're in the same club). With his 4.10 gears, line-loc and DR's, he would always have me by a car or two out of the hole, but I would always run him down before the finish line (on my street tires). I'm not sure why his car never made more power, but I believe he picked up about 12 hp when he added the new cam, hi-flow cats and FL headers.
I was wondering if others here thought I might be better off with a bigger cam and if so, how large would you go? I would still like it to be somewhat streetable, but I am willing to give up a little streetability for more power. Here is a partial list of my current mods:
LT1 CNC Ported Heads
2" and 1.57" severe duty Stainless Steel Valves w/Titanium Retainers
Comp Cams Double Valve Springs
Comp Cams Pro Magnum Roller Rockers (1.6)
Comp Cams Pro Magnum Hydraulic Roller Lifters
Comp Cams Custom Cam 210/224-112
Comp Cams Guide Plate and 7/16 Studs
Hardened Race Pushrods
Custom Chip by Ed Wright
TPIS 1.75" Full Length Headers
3" B&B Tri-Flow Exhaust
3" Dr Gas X-Pipe replacing the Tri-Flow Resonator
Breathless Vortex Air Intake
Be-Cool Aluminum Radiator
MSD Ignition and Coil
And here is a shot of my last dyno pull...
I would appreciate any and all input...
Mike
Edit: Decided to start my own post...
[Modified by luvmy92, 3:25 PM 12/10/2002]
