I'm installing blind spot cameras and in order to power them i need to find the wire that feeds the blinkers individually. If i grab the wire at the bulb, it will trigger the cameras everytime I hit the brakes.
From his post history, he has a '93 automatic. The wire you're looking for is that one that goes into the round silver can that says "WAGNER DOT" on it--that's your flasher. Power should be the single pink wire (the purple wire goes out to the lights, so tying into one of those will cause your cameras to blink with the turn signals).
I only have the service manual for the 94 and 95, so the above color may not be correct. There are only two plugs on the turn signal flasher, so if the colors aren't pink and purple like in my manual, then just use a multimeter to find the one that doesn't blink with the turn signals.
I would use the wires that come from the turn signal switch in the steering wheel. The wires are in the connector on the column. In the pic. I believe it is the lt blue and dk blue are for the front turn signals. Check a wiring diagram to be sure.
