1985 C4 running rich
Old Jun 1, 2020 | 04:48 PM
Nards's Avatar
Nards
6th Gear
Default 1985 C4 running rich
Hello Everyone, I have a 1985 Corvette. I bought the car 2 years ago. I had the engine rebuilt last summer, every since I put the engine in the car runs rich. I hooked up my code reader and it said coolant temp. sensor. I have replaced both of the sensors twice and it's constantly running rich. I replaced the fuel pressure regulator, ECM, IAC, TPS, Injectors, fuel pump, gas tank, and New Distributor. I removed and clean the grounds. Any advice would be helpful. Thank you in advance
Old Jun 1, 2020 | 04:56 PM
KyleF's Avatar
KyleF
Get a Scan Tool and see what the data tells you. What makes you think it is running rich? What is your Fuel Pressure, What are your BLMs, IAC counts, TPS Voltage? Etc. I noticed the one part on your list that is missing is the 02 Sensor. What voltages is the ECM seeing from it?
Old Jun 1, 2020 | 05:17 PM
Nards's Avatar
Nards
6th Gear
What makes you think it is running rich? Black smoke and had to replace plugs a coupe of times because they were wet, and had to change the oil because it smelled like gas. What is your Fuel Pressure 40 and drops to 20 as soon as to turn off the ignition, What are your BLMs, IAC counts I have to check those, TPS Voltage 5.4? Etc. I noticed the one part on your list that is missing is the 02 Sensor I haven't replaced the O2 it was replaced right before I got the car. What voltages is the ECM seeing from it? Not sure
Old Jun 1, 2020 | 07:03 PM
KyleF's Avatar
KyleF
Unfortunately new doesn't mean good, but.... I would definitively start by seeing what the feedback to the ECM is from the O2 sensor. Don't just replace, collect data too. If the 02 is constantly telling the ECM it is lean, your BLMs may be pegged and it is doing all it can to keep adding fuel. Look at 02 Volts, Corss Counts, and BLMs. If 02 is low, BLM is High, and Cross Counts are low I would say it was the Oxygen sensor. If on the other hand the 02 sensor volts are high, BLMs are low, and cross counts are low I would think the issue is either a leaking injector or MAP/MAF issues. I know you said you replaced the injectors, but most commonly what I see on the LTX/L98/LB9 forums is gas in oil = leaking injector.
Old Jun 2, 2020 | 07:07 AM
Mixednuttz's Avatar
Mixednuttz
2023 Corvette of the Year Finalist - Modified
2022 C4 of the Year Winner - Modified
Finalist 2020 C4 of the Year - Modified
What size are your new injectors?
Old Jun 2, 2020 | 07:17 AM
Nards's Avatar
Nards
6th Gear
22 lbs
Old Jun 2, 2020 | 07:35 AM
1Hotrodz's Avatar
1Hotrodz
Not sure of this but, does this engine have a separate cold start injector? This could be a problem. Also, I did notice your fuel press. drops off quickly at shutdown, indicating a fuel leak possibly from the cold start injector. But here again, don't know enough about this model year to give you a definite answer. Just trying to help.
Old Jun 2, 2020 | 08:00 AM
Nards's Avatar
Nards
6th Gear
Yes it does have a cold start injector. Let me look into that and get back to you. Thank you.
Old Jun 2, 2020 | 08:19 AM
KyleF's Avatar
KyleF
Cold start is not controlled by the ECM. It receives power during cranking only and is told to operate by a thermostatic switch near the thermostat housing IIRC.
It too could be leaking, which was a good point.
This would be a situation where the O2 Volts would be high (Rich), BLMs would be low (Pulling Fuel) but you have and obvious rich condition with the plugs.
Old Jun 4, 2020 | 11:09 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
22 lbs
is the engine stock? i understand its been rebuilt but is it a stock rebuild?
85’s were 24lbs injectors, not 22. this may be causing the o2 to see lean condition which causes the ecu to request more fuel this creating the rich condition.
Do you have a laptop computer, an aldl cable (aldlcable.com i think is where i purchased mine) and and a volt meter?
Old Jun 4, 2020 | 11:11 AM
VikingTrad3r
Oil Producer
i see u have a fuel pressure tester.
if you are willing, u can dial in exactly where the fuel pressure is leaking down. do u have two vice grips?
Old Jun 4, 2020 | 11:40 AM
Nards's Avatar
Nards
6th Gear
Stock rebuild. I have a laptop, I need to get the cable. I do have a volt meter. I had the 24 in there and it ran worse. The guy said he had 22 in since he got it. ( doesn't mean it's right LOL)
Old Jun 4, 2020 | 12:38 PM
VikingTrad3r
Oil Producer
i re-read your first post. u have sure tossed alot of parts at it.
id get the aldl cable.
i have a caveat for you with the aldl cable. on the 85, and only the 85, the aldl connection is a tad less useful than with the 86 and up. But for the purposes of what you are trying to solve here, it will still give u what you need.
the tunerpro rt with aldl combo is very useful once it has been setup. its not exactly plug and play....so when u get it, google how to set it up and if/when u have trouble post here and we can help u.
i recently fixed my 87 which was also running rich and through a series of tests it was easy to see what the issue was. in my case the o2 sensor was giving whack values of 0-5mv!
Old Jun 4, 2020 | 12:43 PM
Nards's Avatar
Nards
6th Gear
Thank you for the information. I will keep you all posted.
Old Jun 7, 2020 | 04:12 PM
ctmccloskey's Avatar
ctmccloskey
If your Oxygen sensor is over 24 months or 50k miles then replace it as that was all they were made to do. When the fail they like to fail rich so the engine is not damaged.
Contrary to what some believe these sensors were designed for only 24 months or 50k miles, As they age they send a smaller (narrower) signal and they lag behind the computers need for information which can cause drive ability issues.
Left running too rich the catalytic converter will fail as well.
The Cold Start Injector has wires that power the injector and on my 1988 C4 you can disable it by disconnecting the wires. That doesn't help when you have a leaking cold start injector which can happen like other injectors.
I bought an Older Snap On MT2500 which was a nice scanner in it's day. It provides a wealth of information on my 1988 and my other newer OBD2 vehicles. The best part is that Bosch made a cartridge with Snap On for the Bosh ABS systems the early C4's came with. It allows you to test and verify that the parts are actually working. I have about $300 in the whole kit. Tuner pro is on my horizon but I have not purchased the cables needed to make it work.
Old Jun 8, 2020 | 09:59 AM
playsdixie's Avatar
playsdixie
I put those 22# injectors in....FIC told me to raise fuel pressure to 44 lbs........have'nt had that problem
To 1985 C4 running rich
