AC Pressure Switch Location
Old Jun 12, 2020 | 07:33 PM
BPontuti's Avatar
BPontuti
Default AC Pressure Switch Location
So... this is likely a recurring question for those that have been in the forum for some time. I am looking to wire a WB O2 tomorrow and I need to determine the location of the AC Pressure Switch to which I should feed the 0-5V signal. I’ve searched like crazy but I don’t have a reference for the 93. Help?
Old Jun 12, 2020 | 08:38 PM
Hot Rod Roy's Avatar
Hot Rod Roy
What does the O2 sensor have to do with the a/c? It sounds like you need a FSM (Factory Shop/Service Manual).
Old Jun 12, 2020 | 08:40 PM
FrankieD's Avatar
FrankieD
Brent, a couple of links that should guide you where its located
https://www.ecklerscorvette.com/corv...1992-1993.html
https://www.corvetteforum.com/forums...or-93-lt1.html
https://www.corvetteforum.com/forums...nt-1992-a.html
Old Jun 12, 2020 | 10:27 PM
BPontuti's Avatar
BPontuti
Default AC pressure switch
Thanks Frankie,
I did turn these links up in searches but i am just getting hung up on the pressure “switch” nomenclature. A switch is either off or on. The WB output is analog... so I’m just trying to be sure the input is the correct input. Would have thought that the input would have been a transducer type analog sensor.
Old Jun 12, 2020 | 10:34 PM
FrankieD's Avatar
FrankieD
another helpful lead
https://www.corvetteforum.com/forums...0-180-psi.html
To AC Pressure Switch Location
