New C4 Owner
I'd really like to see some photos of the engine bay if you don't mind. It would help me understand better what you're working with, if anything might have been removed/added by the PO, etc. I think a lot of help could be had from the forums if you're able to post a couple photos. For instance, do you still have all the EGR/emissions crap on the car? A lot of hot rodders remove it because it cleans up the engine bay a lot as well as deleting a ton of potential vacuum leaks. The fact the plenum just fell off sounds like someone has pulled it off quite a few times before. While you were in there, did you notice any issues with gaskets on the runners? Just a thought.
On the drivers side, there's a tube that comes out of the intake manifold in between the plenum runners, and goes to the charcoal canister in the front on the driver's side. It's been a PITA for me as it seems to constantly leak-might be worth checking out. Also, if your fuel pressure regulator isn't working, it could be leaking vacuum (and fuel!)-might solve both your problems.
Sounds like you're pretty capable already, probably way ahead of me...but that's my $.02 anyway.
The plenum and runners were CAKED in carbon, oh and I didn't have a CSI which I presume 85 MY was supposed to have. I'm completely lost on what this car should and shouldn't have.
I didn't check the regualtor diaphagm while I had the plenum off because I was scared to tear it, I want to check the fuel filter first before I call it dead.
AIR pump is easy too, just need to get a pulley to put there instead. Some of the piping for the AIR can be a PITA to get off unless you're willing to cut it. I'd say double-check your laws before doing that, I have the benefit of not needing to pass emissions because I live in BFE. You probably won't get much if any horsepower from deleting the stuff, but it sure cleans up the engine bay a whole lot to have it gone. I've still got my EGR system but I'm seriously considering deleting it for that reason.
While you're doing all of this cleanup work, you might bypass the coolant to the throttle body as well. It's there to prevent icing, but unless you plan on driving in pretty cold weather, you don't need it. Again, it's not a performance thing, but it will clean up the bay more and it's really easy to do.One less thing that's going to be in your way all the time.
Have you flushed all the fluids? Because seriously, do that before you start driving the car. You might save yourself a huge headache later and learn about problems before they get expensive. Sounds like the previous owner was the meddling type, and if they didn't do something right you could end up screwed. I like to KNOW it was done right. Again, just my $0.02
. The coolant tested ok, but the oil, and brake fluid are being fluahed out, as well as the trans fluids. Im not sure what the PO did and didn't do, all I know is it has a new clutch. Any and all help is appreciated.
Clutch can be a pain to bleed if you don't have a friend to help you, or even if you do. I've had a bleeder kit recommended to me (the kind that vacuums fluid through) but never used one; supposedly it makes the process easier. I've also had poor luck with aftermarket-maybe you can get an original one and refurb it?
Secondly, and this is a super stupid question, do you have to clear codes after fixing issues or will they clear by themselves? I've noticed that if the car is warm, I can start it up and for about 3 seconds it will idle super smoothly, but then the check engine comes on and it idles like crap, I haven't tried clearing the codes yet but now I'm curious.
