Headlight Thumping Noise
Old Jun 23, 2020 | 01:18 PM
ROUTE 66's Avatar
ROUTE 66
Default Headlight Thumping Noise
My 1993 doesn't get driven much. I took it out yesterday for a short drive. Turned the headlights on. I noticed the left light did not rotate to the full up position as quick as the right one.. When it got to full up it made a thumping noise for about 2 seconds. Then when I turned them off at closing and at fully closed it did it again for about 4 to 8 seconds. Any one ever have this happen if so what was the problem. Your help would be greatly appreciated Thanks Ellis...Just a note.. I have not turned the headlights on in this car in many years.
Old Jun 23, 2020 | 01:22 PM
s carter's Avatar
s carter
Yes common headlight bushings/pucks have failed, is there possibly a white dust under failed light
review this video to see if this is your problem,this guy did a bronze gear conversion which is a little more expensive than just a puck replacement gears themselves rarely fail but I have seen it so bronze is not a bad road to do while your there.
https://m.youtube.com/watch?v=sPj1kJm4AnU
Old Jun 23, 2020 | 03:22 PM
turtle96's Avatar
turtle96
except I don't see a need for the bronze gear. Added expense for questionable benefit. I reused my plastic gears. The pellets are what fail.
Old Jun 23, 2020 | 05:08 PM
CharlieNC's Avatar
CharlieNC
Check chrisfix YouTube video for diy details.
Old Jun 24, 2020 | 10:07 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
Mark does an excellent job of showing the repair. It's a 4-part video. It helped me in doing both of mine (same problem and sounds as you).
No need for a bronze gear.
Old Jun 24, 2020 | 12:06 PM
95LT1ZF's Avatar
95LT1ZF
This is on my list for the summer as well.
Old Jun 24, 2020 | 12:16 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can simply fill the gear w/epoxy. Don't even need to buy the pucks.
Old Jun 24, 2020 | 12:48 PM
mako41's Avatar
mako41
Yes I agree!
Your OEM plastic gears should be fine. It was the earlier model year C4's that ran two plastic gears that benefited from bronze replacement gears, not the single plastic gear/headlight system you have in your '93.
https://www.corvetteforum.com/forums...r-plastic.html
Old Jun 24, 2020 | 03:54 PM
ROUTE 66's Avatar
ROUTE 66
Default Thank You
Thanks for all for your help. Now I know what to look for.
To Headlight Thumping Noise
