Fuel Pressure Testing:
Old Jun 24, 2020 | 03:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Fuel Pressure Testing:
Just picked a test kit but after screwing hose onto the Schrader of my '89 the reading was zero with key on for >2min.
Then tried it on my '88 (which starts & runs), same deal zero pressure even with engine running.
Examined the end of the test hose to find there was no pin to depress the Schrader???
All vids I've seen the hose is simply screwed onto the Schrader w/o need to remove the valve core.
Am I right here??
Old Jun 24, 2020 | 06:58 PM
playsdixie's Avatar
playsdixie
Am I right here??
remove the cap, then screw on the hose to the gauge.....you should be able to depress the pin on the top of the schrader valve to see if anything squirts out....if so, she's got some kind of pressure
Old Jun 24, 2020 | 08:13 PM
knikula's Avatar
knikula
maybe not screwed on far enough to push that little button in... don't get your face too close to that fuel rail.... and don't inject gasoline into your hand.
Old Jun 24, 2020 | 10:04 PM
aklim's Avatar
aklim
Gas injection isn't possible at less than 50 psi.
I would take a pic of the end you are screwing onto the schraeder valve. Not sure why there is nothing there.
Old Jun 25, 2020 | 12:06 AM
65Z01's Avatar
65Z01
I think this test kit from AZ had been loaned out and someone messed with the hose end.
Going to return the test kit for a refund and find another unit elsewhere.
Thanks for the confirmation on how this "should" work.
Old Jun 25, 2020 | 09:07 AM
playsdixie's Avatar
playsdixie
it's about 8 bucks for a hose and gauge at a auto parts store....get one
Old Jun 25, 2020 | 09:10 AM
aklim's Avatar
aklim
Which one is that? THIS is $45
Old Jun 25, 2020 | 09:16 AM
playsdixie's Avatar
playsdixie
I'm really guessing, I got a gauge with a short little hose and connector at advanced auto.....didn't think it was very much....not 45 bucks anyway
Old Jun 25, 2020 | 09:33 AM
aklim's Avatar
aklim
I'm not sure which one you got. You can get the cheaper one without the braiding but It is about 30 some. I probably wouldn't trust anything as cheap as a $10 fuel pressure gauge. Couldn't afford it
Old Jun 25, 2020 | 11:29 AM
playsdixie's Avatar
playsdixie
you're right, I checked , I paid 40 something for mine.....shaved the price for the war dept......
To Fuel Pressure Testing:
