My ‘89 is making weird noise when I turn it on, I’ve told it was the pulleys, so I want to hear it from you guys, if you can help me find all the pulleys that I need and good brands, I have an L98 engine, keep me updated guys thank you!
Telling you which pulleys you need is something we can't really tell from behind a Keyboard. Someone needs to put an Ear to it, pull the drive belt and feel for looseness and seen if they turn smoothly.
Is your drive belt old and Cracked?
no but the tensioner pulley is lose, it wobbles, and then the pulley next to the radiator, the previous owner idk what he did but it was welded and it’s a bit pushed back. I don’t know what the problem is I’ve taken it to 3 mechanics and they all say it’s this pulley and that pulley, and I’m just so confused lol hhhhhhhalppp
About 20 years ago, there were some guys remaking pulleys with different diameters to lessen the load on the engine to gain free horsepower
i thought it was a little dangerous, since i thought they didnt know what they were doing.
i have probably all the pullies from another car.
it was an 86.
i have a tensioner with a new bearing as well.
hillenger 512@***.net
mention pullies, and maybe we can fix the problem.
Under drive pulleys were pretty common and not that dangerous.
None of that sounds right... under drives did not require welding by design. If your tensioner is loose, please tighten it first and make sure the pulley spins smoothly.
