Crossfire tbi dumping fuel
Old Jun 26, 2020 | 06:29 PM
Miketrev18's Avatar
Miketrev18
Cruising
Default Crossfire tbi dumping fuel
Hello All,
I have a 1984 Corvette with the crossfire I rebuilt the tbi's the front tbi is dumping fuel from the spring not the injector I don't know what is causing it.
also the car hasn't been started in 13 years got it started but then flooded itself out from the front tbi
Old Jun 26, 2020 | 10:02 PM
Kevova's Avatar
Kevova
Spring? You probably need to replace seals and gaskets. I would install reseal kits in both.
Old Jun 26, 2020 | 10:11 PM
Miketrev18's Avatar
Miketrev18
Cruising
I already rebuilt both TBI's
Old Jun 26, 2020 | 10:22 PM
Kevova's Avatar
Kevova
You need to review what you did on leaking tbi. Faulty part. Hard parts not flat or pitted.
Old Jun 26, 2020 | 10:34 PM
Miketrev18's Avatar
Miketrev18
Cruising
It all look good but once I start cranking it it comes out from the little space where the spring is and not out not from the injector
Old Jun 26, 2020 | 10:43 PM
Kevova's Avatar
Kevova
Are you talking about fuel pressure regulator? Did you replace diaphragm?
Old Jun 26, 2020 | 10:45 PM
Miketrev18's Avatar
Miketrev18
Cruising
It's the front tbi so I believe it's the compensator spring and there's a little slit in the side of it of the housing and the fuel comes out of there and I replaced both diaphragms and it was doing this before I rebuilt the Tbi's
Old Jun 26, 2020 | 11:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You either didn't install the diaphragm right, or the one that you installed has a tear/hole in it. Take it back apart and see what is wrong.
Old Jun 26, 2020 | 11:51 PM
Miketrev18's Avatar
Miketrev18
Cruising
Ok I'll try that but it was doing the same thing before I replaced the diaphragm
Old Jun 27, 2020 | 12:04 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well...somehow fuel is getting from above the diaphragm, to below it. You need to figure out why.
Old Jun 27, 2020 | 12:07 AM
Miketrev18's Avatar
Miketrev18
Cruising
Could the fuel line be plugged on the return line?
Old Jun 27, 2020 | 12:15 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It could. That still shouldn't cause that diaphragm to leak though; the stock pump is only capable of producing about maybe 14 PSI, with the return dead-headed. The system should be able to run much higher pressures than that w/o leaking.
It wouldn't be hard to unbolt the return line and try to blow air through it back to tank...
To Crossfire tbi dumping fuel
