3 row radiator update
Old Jun 27, 2020 | 02:28 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default 3 row radiator update
The new 3 row radiator is in. I had to trim the rubber saddles it sits in on both top and bottom so it would sit down in them like it should. Also had to open the filler neck opening just a bit so the neck would go through. That was all it needed to drop right in and button it up. The results,,, sitting in the garage idling ac on full blast and one fan on,,,182!! Temp outside was 80
Haven't had it out yet so I don't know what it will run on the highway, hopefully not too cool.
Old Jun 27, 2020 | 05:50 PM
84 4+3's Avatar
84 4+3
Hood up or down? Mind creeps to 200 hood down but hood up holds the thermostat temp
Old Jun 27, 2020 | 07:32 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
these are the ebay units?
Old Jun 27, 2020 | 08:20 PM
84 4+3's Avatar
84 4+3
Mines not but his is. Aluminum is aluminum. Should pull out the same energy size for size.
Old Jun 27, 2020 | 10:42 PM
Midnight 85
Yes but not one of the real cheap ones, it's a Champion. Total was just over $200
Old Jun 27, 2020 | 10:44 PM
Midnight 85
It may not make a difference on mine. Toledo Pro hood, they have great ventilation at the rear. If it ever quits raining I'll get it out and see how it is in traffic.
Old Jun 27, 2020 | 11:05 PM
84 4+3's Avatar
84 4+3
Gotcha. I ran in upper 80s and a high relative humidity last week and even a few semi Mexico pulls just dropped the coolant temp hard. The highest I saw was 208 or so and moving around it ran around 185. The improved hood airflow helps though.. those side vents are entirely too small imo.
Old Jun 28, 2020 | 12:17 AM
Midnight 85
IMO the side vents are good for looks but not much else. I was very pleased with the TP hood the first time I felt all the heat coming out while the engine was running and fan on. I actually drew my hand back because I had never felt it before and was used to the stock hood with no vent.
Old Jun 29, 2020 | 03:06 AM
Midnight 85
It was mid 80's yesterday so I took the car out and drove around in traffic, windows up ac going strong, and one fan on, the car peaked and stayed at 192. oh, and the hood was down,, just kidding you 84 4+3 don't take offense. As far as I'm concerned, case closed.
Old Jun 29, 2020 | 08:11 AM
84 4+3's Avatar
84 4+3
Excellent. Now I forget, you have a decent amount of work done to the engine no? Or are you close to stock?
Old Jun 29, 2020 | 12:03 PM
Midnight 85
Not even close to stock, 383, crate engine from ATK, dynoed before I got it @ 435 with a 750 carb. No idea where hp is now but ATK estimated over 450. Edelbrock Pro Flo intake with Fitech 102mm throttle body.
Old Jun 29, 2020 | 12:15 PM
84 4+3's Avatar
84 4+3
Okay. (Hard to keep track of everyone lol) So we're probably turning out similar amounts of heat. I should be low 400s but I'll know once its dynoed. The stock rad couldn't handle much other than a leisurely cruise...
Its good to see there are other options for people looking for upgrades
Old Jun 30, 2020 | 12:02 AM
Midnight 85
Yeah, I don't get on the forum much any more, not like I used to anyway. My combination might be a little better known if I did.
Old Jun 30, 2020 | 05:15 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It’s well known to some of us!
Old Jun 30, 2020 | 07:50 AM
84 4+3's Avatar
84 4+3
All good magoodI don't even remember what I did to mine yesterday. I probably read it a while back but I'm just so burned lately I can't remember.
To 3 row radiator update
