C4 corvette Codes OBD1
Old Jun 28, 2020 | 04:13 PM
Dominic G.'s Avatar
Dominic G.
Default C4 corvette Codes OBD1
I have a 1993 corvette and am trying to decypher the codes that displayed on the dash.
When the codes were flashing they had a tiny number under them which i would assume would identify which computer/system code it is...
for example the first sequence flashed H27 H32 H34 H36 H38 with a tiny number 1 at the bottom of the screen. Could anyone let me know where to find what these codes mean?
Old Jun 28, 2020 | 04:27 PM
s carter's Avatar
s carter
http://www.chevythunder.com/199295_l...uble_codes.htm
Old Jun 28, 2020 | 05:11 PM
Dominic G.'s Avatar
Dominic G.
I have found that list, just not sure which sequence of codes that it correlates to... As listed above I got a sequence of codes with the number 1 at the bottom, then the next sequence showed a number 4 with more codes, then a number 9 at the bottom with another code.
Sorry if im just being an idiot but I just dont understand.
Old Jun 29, 2020 | 02:24 AM
Nomake Wan's Avatar
Nomake Wan
This is a much better link: https://tech.corvettecentral.com/201...trouble-codes/
Module 1: CCM
Module 4: ECM/PCM (Engine/Transmission)
Module 9: ABS
Old Jun 30, 2020 | 02:18 PM
Dominic G.'s Avatar
Dominic G.
Youre the best! Thank you so much !
To C4 corvette Codes OBD1
