85 Brake Issue
Old Jul 10, 2020 | 08:54 PM
jguard68's Avatar
jguard68
Default 85 Brake Issue
I just put on new pads and rotors a few days ago, brakes were bled perfectly. Now, just the last couple days, my brake pedal becomes soft and wants to travel to the floor, if I give it a quick pump it becomes firm again. I checked for leaks as someone pressed the brake pedal and I found no leaks, and the master cylinder was full of fluid. Is it possible the brakes need bled again, even though we were very thorough the first time? I appreciate any input.
Old Jul 10, 2020 | 11:52 PM
IBVETN2's Avatar
IBVETN2
Possibly, but I would suspect a bad master cylinder.
Old Jul 11, 2020 | 01:22 AM
KMS88Cal#16's Avatar
KMS88Cal#16
Have you changed out your rubber brakes lines? They can collapse internally and cause fluid flow problems.
Old Jul 11, 2020 | 11:51 AM
LiveWire1's Avatar
LiveWire1
A bad master cylinder can be identified this way:
Press the brake pedal so that it's firm under your foot. If you let off the pressure slightly, then the pedal will go to the floor on its own. If it's consistently soft, or firm then goes soft after a while, or if you can pump it up, then it's air in the lines.
Check all around the master cylinder for fluid runs on the bottom of the brake booster. Occasionally, it could leak into the booster, but that's rare.
Old Jul 11, 2020 | 12:01 PM
Mrvettenick's Avatar
Mrvettenick
If you're pretty sure they are bled correctly, then I would suspect the master. They can leak internally without any external indication, One dead indication will be to pump up the brakes, then wait....if the pedal sinks slowly, then I would consider the master.
To 85 Brake Issue
