Laying it all down
Old Jul 13, 2020 | 12:34 AM
Spencer Ducharme's Avatar
Spencer Ducharme
Default Laying it all down
Ive got myself a pretty trick former 4.8 LS retaining the factory crank after having it polished and cleaned, custom forged rods rods and a 3.903 inch bore. I wanted a screamer motor for my 84. But my question is, because its an LS, i would love to see anywhere from 800 - 1000 hp in a boosted application. My question however, is if my dana 44 with a detroit trutrac diff and hardened half shafts is going to
1. Survive at that power on sticky tyres, and
2. Actually be able to hook it all up
Sure 1000hp would be lovely for bragging rights. But i want to do a bit of everything in motorsports and if it isnt going to hook then im really not interested. What should i cap the build off at so im not struggling for traction all the time given the fact it's a c4? Car has a 12 point cage going in soon, and may do a semitub at some point depending on if i need more rubber.
Old Jul 13, 2020 | 02:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
Even 800...Id be looking to put a solid axle in it right off the bat, you will be breaking that IRS. Some here have gone sub 10s but eventualy put a 9 inch in after breaking all the "unbreakabe" irs stuff you see advertised. Sure wouldnt want a failure at 130mph
Old Jul 13, 2020 | 04:01 PM
Spencer Ducharme
thought real long and hard about that option. My only debauchle is i want to road race and track this thing in addition to drag racing and street events. I dont want to lose my handling to the solid rear. But if something like say, a 3 link with a watts link could cut it without killing off most of my cornering capability, then i would be sold.
Old Jul 13, 2020 | 11:21 PM
JoeNova's Avatar
JoeNova
Torque breaks parts. Leave the 4.8 at stock displacement and you'll still be able to make tons of power, but without the torque in the places its most likely to break stuff.
Old Jul 13, 2020 | 11:39 PM
Kevova's Avatar
Kevova
Parts survival will dependent on tuning ability. Enough power to launch without out spinning and increase power while keeping traction. I would sell IRS and install either 8.8 or 9 inch.
Old Jul 14, 2020 | 08:06 AM
C409's Avatar
C409
..... The Dana 44 is a lot tougher than many of you think ! ... lt's shock loading that does the most damage ... think high rpm clutch dumps or trans brakes ... torque will hurt 'em too ... nitrous anyone ? ... like most parts , they don't appreciate a lot of abuse ... do your thing sensibly and you will be OK .....
Old Jul 15, 2020 | 10:37 AM
Spencer Ducharme
i really like the above mentioned idea of keeping the torque low and just making gobbs of hp. I finally got the exact math and the motor will be a 312ci or a 5.1 retaining the stock stroke of a 4.8 with the bore of a 5.7L at 3.903. So it will probably rev real well and be a fun little oddball combo motor. As for the torque. Some people prefer their vette to have that characteristic testosterone fueled shove of torque from the get off, personally, i prefer the motor to make it all in mid to high so my... uh.. shall we say spirited driving habits dont have me hooning around on public roads. As for the d44 i think i may try to go for that option and just keep the motor away from any stroker kits. Any reccomended d44 mods in addition to the detroit trutrac and cryoed half shafts?
Old Jul 15, 2020 | 10:48 AM
JoeNova's Avatar
JoeNova
I've ran multiple 9 second passes in a stripped down C4 with a turbo 4.8 and a bone stock Dana 36 and stock rear everything else.
I dont understand the point of boring out a 4.8 block and then adding boost. You're not increasing the peak power potential at all, you're just increasing torque and thinning the sleeves. The block kept at stock 4.8 displacement is virtually indestructible. The thick sleeves combined with low side-loading from the excellent rod/stroke ratio along with reduced torque will put incredibly low twisting force on the block. Other than lifting a head, you wont be able to harm the block. As soon as you bore almost a quarter inch off of the sleeves, a lot of this goes out the window.
Old Jul 15, 2020 | 11:02 AM
Spencer Ducharme
under normal circumstances i would agree with you entirely. More cylinder wall thickness is always better for boost. The block i bought however, doesnt agree with you. Idiot who owned it before me didnt really take care of it. It had scuffing on some of the cylinder walls and needed to be bored over to fix it. He also managed to snap a valvespring in half and drop a valve on No. 6 piston leaving a lovely little gash there. So the whole bottom end except for the crank was basically useless. To preface. Im a ripe 20 and i know that a junkyard 4.8 could be easily purchased for the same cost of machining as what ive done here. However i recieved these pistons and the block for free. (Pistons were from a buddy who builds engines not the idiot who owned the block). And im trying to just budget this thing together for now. Its definitely not the most ideal. But its saving me a bit of money. 600$ for a junkyard 4.8 and 500$ for these pistons. So im somewhat forced to go with it.
Old Jul 15, 2020 | 11:11 AM
JoeNova's Avatar
JoeNova
You could sell the parts you have and buy 3 stock running 4.8s that don't need machine shop downtime, assembly, or tons of nickel/dime parts.
Or you can put it together with the thin sleeves, attempt to make big power on your first ever turbo LS build, and destroy everything you have and have to start all over without the parts to sell anymore.
You're basically putting something together that is already leaning on a crutch, waiting to fall. I'd consider much more mild boost goals of 500-600 HP with that setup.
The forged rods and pistons will be doing you zero favors if you've weakened the block below the point of what the stock rods and pistons can handle.
Never go full potato on your first build. You'll lose more than you learn.
Old Jul 15, 2020 | 04:33 PM
C409's Avatar
C409
..... The TruTrac is not on any of my lists anymore ... too heavy , open diff until you hammer it , non-serviceable internals , expensive too ! ... I haven't cryoed any parts either ... keep it stock , torque check the Traclok clutches (or have a custom spool machined) and keep the half shafts as close to parallel with the pavement as you can ... and ... don't pull into the burn out box if its dry , make them spray it with water before you go in ! .....
Old Jul 15, 2020 | 05:01 PM
Kevova's Avatar
Kevova
Trying to have all purpose car will add to the challenge as opposed to a dedicated drag, suto x or road race car. The chassis set up will need to.be adjusted for the different events. Not that it can't be done; you want to build car for primary event. Then adjust toward secondary.
Old Jul 15, 2020 | 05:25 PM
JoeNova's Avatar
JoeNova
My car is setup for autocross and road course with double adjustable short travel motorcycle coilovers on all 4 corners with stiff spring rates, and it does awesome drag racing lol.
Then again I've put about 300 hours of work into it.
Old Jul 15, 2020 | 09:48 PM
84 4+3's Avatar
84 4+3
I would think unshrouding the valves still helps no?
You can make anything work excellent with the correct amount of effort. I've seen combos do ridiculous things that it just shouldn't be able to. Can't explain why it works but it does and we just leave it at that. Why mess with it if its already doing things it shouldn't be able to do lol.
Old Jul 15, 2020 | 10:15 PM
JoeNova's Avatar
JoeNova
Valve shrouding, valve size, quench, and even head flow matter significantly less when you're relying on boost for power.
The stock 4.8 heads (the worst flowing of the LS heads) have been over 1000whp completely unported with stock valves thanks to boost.
To Laying it all down
