ARP Head bolts
Old Jul 17, 2020 | 09:52 PM
Furias15x's Avatar
Furias15x
Default ARP Head bolts
Hello,
Getting ready to torque the heads down tonight.
ARP paper in my box says 70lbs. Doesn't specify for aluminum or a different number for the short bolts.
I have looked over many threads here and it sounds like most go to 65 on the long ones and 60 on the short ones.
Do I follow ARP and go 70 on all or less on the shorter ones?
Thank you
Doug
Old Jul 18, 2020 | 01:32 PM
FostersPerformance's Avatar
FostersPerformance
ARP knows their stuff....always follow the directions they give. And use the assembly line they provide.
Old Jul 18, 2020 | 05:38 PM
jazfe's Avatar
jazfe
I'm following APR's advice when I change my heads. They are aluminum aftermarket. The manufacture of the heads suggested APR bolts and to follow the APR instructions.
Old Jul 18, 2020 | 06:19 PM
383vett's Avatar
383vett
I torque to 70 with ARH bolts and aluminum heads.
Old Jul 18, 2020 | 08:11 PM
GregMartin's Avatar
GregMartin
I used arp bolts on my Edelbrock heads. The doco that came with the heads said 65 ft pounds in three steps (40,55,65). So that’s what I did. Haven’t blown a head gasket yet.
Edit: Also always use a quality head gasket if you don’t want future problems. For Aluminum heads a Fel-Pro FE1010 is the go.
To ARP Head bolts
