Protecting the ECM
Old Jul 24, 2020 | 12:36 PM
PoprocksC4's Avatar
PoprocksC4
Default Protecting the ECM
anybody seen anything on options for protecting your ECM.
I've got 43k on mine and it seems that high heat is the culprit of damaging the soldier connections.
Hate to replace it AGAIN.
Old Jul 24, 2020 | 08:43 PM
hcbph's Avatar
hcbph
It would help to know your year of car, I'm assuming it's one of the later C4 as mine is in the dash.
Just a swag here, what about some of the heat shielding used in the interior, could it be applied to the surface of the unit similar to what's used inside the car?
Old Jul 24, 2020 | 10:18 PM
PoprocksC4's Avatar
PoprocksC4
93 LT-1. it's under the hood
Old Jul 24, 2020 | 10:36 PM
SJW's Avatar
SJW
If your underhood temps get hot enough to reflow solder inside of the ECM, saving the ECM is going to be the least of your worries.
The ECM has an integral heat sink. If you insulate the unit, you'll trap heat inside of the unit. Not a formula for success.
Live well,
SJW
Old Jul 24, 2020 | 10:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
My car ('92) has almost 200k on it. No problems w/the ECM. Not sure why you're having ECM/heat issues. I'd be looking for other root causes.
Old Jul 24, 2020 | 11:02 PM
Kevova's Avatar
Kevova
If a reputable shop services the ECM it should last another 27 years or longer. The difference between mass production and a technician inspecting every joint.
Old Jul 26, 2020 | 12:06 AM
PoprocksC4's Avatar
PoprocksC4
True, it shouldn't get hot enough to melt soldier! Just wandering if anyone had luck protecting this vital organ.
I've read it to be a common issue with the 92/93 models. Mine only has 42k garage kept. But it is 27 years old. The issues are random and disconnected.
A/C quits working
Speedo drops to 0 mph
Rev limits at 3k
I get code 1. C41 and 4. ERR code.
"Can't communicate"
The wiring is all good, no corrosion no rust anywhere.
All signs currently point to the ECM.
Old Jul 26, 2020 | 11:19 AM
JimLentz's Avatar
JimLentz
I sent my ECM to SIA Electronics a few years ago and I have not had any more random issues with it.
Old Jul 29, 2020 | 01:56 PM
easy2no's Avatar
easy2no
Sent mine to Sia also. Easy to work with, good turn around and no more engine shut off in the middle of traffic!!!
Old Jul 29, 2020 | 11:50 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Ecm
When i bought my 86, it would warm up, and at the same spot 5 miles down the road, the idle would be 1300 rpm, The dash would go nuts and the mileage Readout would read all 8’s.
changed ecm and all went normal.
try driving with the hood unlocked to promote airflow.
if you see a change, try cleaning out the air path through the radiator area.
To Protecting the ECM
