1986 C4 problems
Old Jul 25, 2020 | 10:34 PM
Nicole Wentz's Avatar
Nicole Wentz
6th Gear
Default 1986 C4 problems
I have a 1986 C4 Corvette, I had a problem where I'd be driving down the road and it would just die no warning , that was the ignition switch, now that I got that fixed the only way I can keep it running when I slow down is to adjust the idle up high, does anyone know what might be my problem, this is my first Corvette, thanks for any and all help
Old Jul 25, 2020 | 10:41 PM
Vette_DD's Avatar
Vette_DD
Welcome to the forum.
Wait for a moderator to move this thread to the C4 section of the forum. They'll be glad to help you.
Old Jul 25, 2020 | 10:53 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Jul 26, 2020 | 02:53 AM
Moved to C4 Tech.
Old Jul 26, 2020 | 08:06 AM
jazfe's Avatar
jazfe
Idle air control is the first thing that comes to mind. I have an 86 as well and when my car comes to a stop the idle is around 1000 rpm for just a few seconds then drops to 800. My engine is modified as well as my ECM. I would have to look up the factory idle setting. There is a good write up in the DIY section of this site about how to set the idle on the L98 engine.
Do you have basic tools like a timing light and a volt meter?
Old Jul 26, 2020 | 08:46 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
google minimum idle adjustment on a L98 corvette TPI. Carry out that procedure then report back.
Old Jul 26, 2020 | 09:06 AM
Nicole Wentz
6th Gear
thank you I will take a look at that this morning and see if this could be it thank you for your help
Old Jul 27, 2020 | 11:54 AM
playsdixie's Avatar
playsdixie
Welcome!!!.....all this trouble and no codes?......jump a/b on your aldl below the dash , drivers side, google or search here how to read the codes.....(it's the flashes of your check engine light)
Old Jul 27, 2020 | 12:35 PM
KyleF's Avatar
KyleF
This, and also check you fuel pressure engine idling with the vac line off the Fuel Pressure regulator.
Old Jul 27, 2020 | 04:30 PM
1985 Vette's Avatar
1985 Vette
As others have stated, I'd check the minimum idle adjustment, then test the IAC valve, then I would check the Throttle Position Sensor (TPS) adjustment.
Here's the procedure to adjust minimum idle speed. My 1985 and 1988 Corvette Factory Service manuals omit steps 4 and 5, which are very important.
http://repairs.willcoxcorvette.com/1...ent-procedure/
FYI: The procedure above says to set the min idle to 450 RPM and the FSM says 400 RPM. I was unable to get it to stay running this low.For the 1985 Corvette, I set the minimum idle speed to 560-570 RPM. The car idles at 610-610 RPM in drive, 630 RPM idle in drive with AC on, and idles at 750 RPM in Park....
One other note, make sure you don't have a Tech 1 or any scanner connected to the OBD1 port, as it will raise the idle. I learned this the hard way.
The IAC test procedure and TPS adjustment is in the FSM. If you don't have one, I or anyone else can post the procedure for you.
Old Jul 28, 2020 | 03:05 PM
Nicole Wentz
6th Gear
changed the iac wasnt it going to change the tps tomorrow . I took it to my garage and they told me it was my tps , I'll let yall know how it turns out again thank you for all the help
Old Jul 28, 2020 | 03:34 PM
ctmccloskey's Avatar
ctmccloskey
Hello Nicole Wentz,
Be careful with your IAC as some of them have a different style and shape of the pintle which makes them not work in my C4. I bought a new one from a NAPA store and the part was the wrong shape. The same part number had two styles of pintle that we found in the NAPA warehouse. I suggest to folks who are going to replace this part take your old one to the store to compare before buying.
Welcome to the wonderful world of Corvette Ownership!
Welcome to the Corvette Forum!
When you have questions "we" will try to answer them quickly and correctly!
Old Jul 29, 2020 | 09:10 AM
Nicole Wentz
6th Gear
Originally Posted by FX VETTE
Welcome to the CF!
thank you , yall are very helpful
Old Jul 30, 2020 | 12:03 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Tps
I have an 86.
when i first bought it, I thought i would wash the engine area.
after cleaning it, it wouldn't idle at all. Turns out, the tps was never sealed at the factory, so moisture got in it and messed up the signal to the computer.
look at yours, there should be a line where they glued the side on to the tps. There should be a discoloration around the entire curved Edged plastic piece, and it should be the rubber that they sealed it with, You can make impressions in it with your fingernail.
if the glue is not there, u need to replace it anyway.
but check vacuum hoses before spending any more money.
Old Jul 31, 2020 | 10:39 AM
Nicole Wentz
6th Gear
there is no dash cluster I have to replace the dash cluster they fried the whole thing before I got it
Old Aug 3, 2020 | 08:32 AM
badduxx's Avatar
badduxx
Feel each battery cable like right after you start it. I had an issue with mine in which the positive battery cable became less conductive, and when the engine/transmission warmed up it would occasionally stall as well as throw check engine lights, not start all the time, etc. That is where I would start. I spent a year doing all kinds of testing, replacing parts, etc and scratching my head. I might even suggest doing this proactively because the cables are cheap. I had no idea how important clean, proper power was for this engine system. If you decide to go this route, I can tell you how I got the cable in place because it is kind of a pain to fish through. It goes behind the engine like on the top of the transmission area. Here is a link for the cables I used:
https://www.rockauto.com/en/catalog/...ery+cable,2500
Old Aug 4, 2020 | 07:00 PM
GregMartin's Avatar
GregMartin
The ALDL connector is under the dash (drivers side towards the middle of the car). You put a jumper between pins A and B. The check engine light will flash to reveal what codes are set. Google or search this forum for how to do it. You don’t need the LCD dash installed to perform this test.
Also get a genuine GM Factory Service Manual (FSM) you will need it.
Old Aug 6, 2020 | 04:14 AM
Nicole Wentz
6th Gear
Originally Posted by ctmccloskey
Hello Nicole Wentz,
I changed the tps and was told I could unplug the iac the idle is ok not as high as it was before the only thing is when u step on the gas and let of you gotta hit the gas again to bring it down
Old Aug 6, 2020 | 04:36 AM
GregMartin's Avatar
GregMartin
Not sure what you mean about unplugging the IAC it’s an important part of the engine control system. If you purchase a new one you have to confirm that you have the correct pintle profile. Also you have to check/set the pintle length (I think not 100% sure on an 86). It sounds to me like you need a scanner and a Factory Service Manual. It would be better to diagnose the faults rather than guessing and throwing parts at it. Also often there is setup involved when sensors are replaced the TPS for example.
To 1986 C4 problems
