90 was stalling, now no start
Old Jul 26, 2020 | 06:33 PM
Ziggy*'s Avatar
Ziggy*
Default 90 was stalling, now no start
Went for drive two months ago , it started back firing then shut off, restarted, ran like crap, then ran fine. (No codes) Now sitting in shop I turn the key to on my radiator fans come on. I cane hear a relay clicking under the dash. I pulled fuses, seems to be in AC but still hear relay noise ( compressor clutch ) Sometime stops then starts an runs fine. Snap On says security problem. Replaced coolant sensor. Checked all fan wiring, still no luck I have FSM not much help why the fans are running....any idea??? thanks Ziggy
Old Jul 26, 2020 | 08:20 PM
Mongo!'s Avatar
Mongo!
My fans both kick on when I jumper ether ALDL connector to read codes. Maybe your ECM is stuck in diagnostic mode....
Also the security will disable the starter via relay when activated I think so that may be the noise...
Old Jul 26, 2020 | 09:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does the ECM control both fans?
Old Jul 26, 2020 | 10:24 PM
Mongo!'s Avatar
Mongo!
On my 85 it seems to but his is a 90 so I am not sure. Just spitballing since he mentions both test mode and the security system...
Old Jul 27, 2020 | 05:34 AM
Ziggy*'s Avatar
Ziggy*
I suspect a relay sticking somewhere under the dash. But can't figure which one from FSM
Old Jul 28, 2020 | 10:53 PM
Ziggy*'s Avatar
Ziggy*
Here's something new. Unplugged the MT 2500 an no fans coming on ( Like it was stuck in diagnostic) But still no start. Will check basics in morning ,Air, Spark,,Fuel
To 90 was stalling, now no start
