Cold start valve
Old Jul 27, 2020 | 05:52 PM
Larry Wegner's Avatar
Larry Wegner
Default Cold start valve
Need advice on removing cold start valve on 1986, Maybe a step by step procedure. I have the pvc tube out of the way and fi wires unhooked. Got the torx bolt out and loose from intake. I found the tab on the gas line connector and the cold start valve turns about an 1/8 turn. I am concerned the connector won't come off the end of the injector, don't want to break anything. Reason I am removing cold start valve is that fuel is leaking out. I got a set of replacement O rings to hopefully fix the problem, but can't figure out how to unhook the injector from the 90 degree fuel line .
Old Jul 28, 2020 | 12:17 PM
Larry Wegner
Thanks for all the responses.
