Electrical ground issue
my door locks occasionally stop working....someone here told me to turn the headlight switch to "dome' and off....magically, they work!!!!
I would start at your battery and work back from there. The battery connections have got to be as clean and functional as possible. I would start by wiping it down and then use a wire brush to clean the posts and get both surfaces nice and shiny. Once the connectors are clean re install them and be sure the connection is tight. Be sure that the battery is fully charged and ready for usage before connecting it to the load. The Corvette needs 12 volts with access to a lot of current so you need a good functional battery.
You might even want to test the circuit to see if the Relay is defective, they can and do fail. I recommend most people to start at the actual battery itself. Measure the battery voltage and then measure it at fuse block. If there is a difference it is likely where the fusible links are powered. On my 1988 C4 Coupe the post is under the side cover over the rear of the battery. The post is mounted on a frame rail and this is where 7 different Fusible Links and their circuits get powered. Sometimes the fuses need to have their surfaces wiped clean every now and then
One of my favorite tools for working on Cars is something called the "Power Probe". I have version 3 and 4 as I use them a lot. This tool connects to your battery and allows you to power or supply battery ground to the tip of the probe. Using a rocker switch you can turn it on and off allowing you to apply battery voltage or ground by simply pushing one side or another of the rocker switch. I have found so many uses for this tool. The newer #4 version can show the voltage kickback after a relay is energized in a graphical format. This is one useful tool especially for Corvettes with their ground issues every now and then.
