Injector O-ring size
Old Aug 6, 2020 | 09:19 PM
finn_the_flying_fox's Avatar
finn_the_flying_fox
Default Injector O-ring size
I had a leaky o-ring on the injector fuel rail on my 92 LT1, so I went down to my local parts store that said Fel-Pro ES 70599 O-rings were the ones to use. Cleaned everything, used soap like you are supposed to installing them, and they now leak worse than before!
Anyone know what size o-rings are supposed to be used? Or preferably a part number. The injectors are the original Multec ones (yes I know they are crap, but its what I have currently).
Old Aug 6, 2020 | 09:34 PM
Whaleman's Avatar
Whaleman
Email Jon at https://fuelinjectorconnection.com/. He will know. Dan
Old Aug 7, 2020 | 08:57 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
The correct size you need are .296" ID x .574" OD.
Old Aug 7, 2020 | 08:58 AM
Red86Z51's Avatar
Red86Z51
AC Delco P/N = 217-3102
Old Aug 7, 2020 | 06:34 PM
finn_the_flying_fox
Update:
Gas seems to be coming out of the middle of the injector where the plastic meets the metal. Is this even possible? Also, the fuel injector plugs are full of gas on some of them. Is this normal?
Old Aug 7, 2020 | 09:07 PM
Whaleman's Avatar
Whaleman
Maybe time for new injectors. Dan PS: You already know it is not "normal".
Old Aug 7, 2020 | 09:28 PM
finn_the_flying_fox
Yea, I've already ordered a set of Bosch 3s from FIC, hopefully that'll solve the issue
PS: I figured as much, but I've seen weirder automotive designs, so I wasn't sure :P
Old Aug 8, 2020 | 06:15 AM
Whaleman's Avatar
Whaleman
They will work great!!! Dan
To Injector O-ring size
