Battery death immeadiately
Old Aug 7, 2020 | 01:12 PM
Filip Musil's Avatar
Filip Musil
Default Battery death immeadiately
Hi,
I have new battery, but every day I have to charge. After 100km I switch off the car and again start is impossible. Can it make radio relay? I think, that will be starter, but I will be glad to listen yours advice.
C4 1986 Convertible.
Thank you
Old Aug 7, 2020 | 02:35 PM
finn_the_flying_fox's Avatar
finn_the_flying_fox
You need to check to see if the battery is being charged by the alternator. Easiest way I've found to do this is to take a voltage reading across the battery with the car running and then shut the car off and take another reading. If the voltage doesn't drop by ~0.5 volts or more from running to shut off, or the running voltage is below ~12.7 volts while running, you have something wrong in your charging circuit.
I would also check that the battery bolts are both tight and not stripped out, its fairly easy to over-tighten the battery bolts and strip them, causing the battery to make a poor connection.
Old Aug 7, 2020 | 08:43 PM
gerardvg's Avatar
gerardvg
Hi
As mentioned check the alternator is charging your battery, the voltage should go from 12v to 14v when starting the car depending on battery charge.
Next check for any abnormal power draw, i have found the antenna can be a problem if it retracts and does not break the switch.
Listen for a click every now and then near the antenna, if it has not opened the contacts the motor o/load can click on and off every minute or so.
That can flatten a battery quite quickly, over a few days when parked.
Check the charge cable from alternator to battery is a good circuit, i think from memory it goes via the starter to battery.
Fusable links can fail, check with a multimeter the alternator is charging.
Check at alternator + and engine ground -, then check at battery + to ground -.
If a battery has been completely and rapidly drained, the plates can buckle and will never be the same again.
so check 12 volts and is holding charge, then start car should go up 13 / 14 volts and the alternator is good.
If not charging then the alternator may have failed.
Good luck
Old Aug 8, 2020 | 11:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Battery
1.You might try disconnecting the alternator battery lead overnight, if alternator has a Bad diode, battery will Not go dead.
2. Run a voltmeter to battery.
pull fuses one at a time and watch voltage.
the pulled fuse will allow the battery voltage To stop going down.
3. Behind the battery take off the fusible links and put an ammeter between the Fusible link and connection point.
when the ammeter moves off zero, that is the bad leg of wiring/ items
To Battery death immeadiately
