Why's my SuperRam so slow?
and we already talked about that earlier in this very same thread. People: Stop worrying about and commenting on the ET. The ET don't matter and R/T matters even less. It's ALL about the trap, and we have that info. The OP is wondering about his power. His trap & weight give us his power, which is somewhere just over 300 NET hp. There are already two, pretty definitive things that should raise concern in this thread, for the OP...and they ain't ET or R/T. They are:
104-106 trap speeds which =~300-320 NET CHP. That is too low for that combo.
This quote from post #1: looks like it should be pulling strong to 5500. Instead, it feels like it really falls off before 5000
Falls off before 5000? Even with the mild cam, those good heads should support power higher than that. The exhaust concern is aligned with the perception that top end power isn't there as well as the weak trap speed.
Its something to look into is all. The easy way is a squirt bottle of water on each tube. There will be a noticeable difference in how fast it sizzles off if it is weak too. That will either agree with your IR gun findings or not...
It always seamed to line up well with real engine dyno results when I could get accurate specifications on an engine combination.
I'm sitting here bored watching TV, so put the specs you posted, AFR 190 heads, Voodoo cam, headers, SuperRam, compression, etc. on a standard 383 short block.
Ran first test with open headers, second a full exhaust giving 8 psi back pressure.
Interesting?
In Photoshop I laid your VE graph on top of my graph, scaled the rpm size to line up, and
the VE to match HP at 2000 rpm and matched the HP-Torque cross point with the 8 psi back pressure graph.
Pretty darn close ... in shape anyway.
and we already talked about that earlier in this very same thread.People: Stop worrying about and commenting on the ET. The ET don't matter and R/T matters even less. It's ALL about the trap, and we have that info. The OP is wondering about his power. His trap & weight give us his power, which is somewhere just over 300 NET hp. There are already two, pretty definitive things that should raise concern in this thread, for the OP...and they ain't ET or R/T. They are:
Unfortunately, fixing the header gasket hasn't been the magic bullet I hoped. It seemed to pull a little better up top, but everyone knows the butt dyno can't be trusted. The datalogs tell a different story - looks like it was running right around the commanded AFR at WOT, which means the volumetric efficiency hasn't appreciably changed. I'm surprised - I thought I'd see at least a few percent higher VE. However, if the exhaust is choked up at the cat like you guys think, I think that would diminish the effect of the bad gasket (higher pressure -> higher density -> lower velocity -> lower frictional backpressure).
I'll order stuff to check the pressure and update when I have results.
Wow, very very interesting! Thanks for running that! I'm actually kinda shocked that those two agree so closely. I guess it's definitely time to figure out if I have a backpressure issue.
Thanks guys. That's exactly how I felt - I'm glad that I'm not crazy in thinking that my engine should be capable of more than that.
Also, most autoparts stores have the back pressure testers on loan. Pay test and return for nothing more than a hold on your card until you bring it back. May be an easier route than buying.
Very good to know about those pressure test kits - definitely going to look into that first thing tomorrow. That would be nice not to have to fab something up. Thanks for the suggestion.
I have a supercharged ZZ4 crate engine and with a stock type Dynomax exhaust I measured over 15 psi of backpressure at the right oxygen sensor fitting, full throttle before shifts.
After a long discussion at a referee test station, he said yes to Carb EQ headers and he didn't care much about the rest of the exhaust, but the converter had to be stock (or legal stock replacement) and in the stock location.
Put on headers and fabricated two 3 inch pipes. Took a 6 inch pipe and walked it thru my shop press with a 3 inch square die inside to make an oval pipe. Removed the heat shield and cut the converter front and back to match the oval pipe and reinstalled the shield. Ran that oval pipe back to mate up to the stock type y-pipe and Dynomax mufflers. Measured about 6 psi of back pressure at the collector, at the shifts with this and passed emissions for about ten+ years. The converter was still to restrictive but the pipes helped a lot.
Now I have dual 3 inch bullet converters and dual 3 inch exhausts back to 2.5 inch Magnaflow mufflers, and barely register 1 psi at full throttle shifts.
Yep, I've read many of your posts! Very familiar with your combination. Any suggestions on getting the SR extrude honed? Since they're so expensive I don't want to risk a shop messing it up somehow.
Do you have a p/n for that cam? And any comparison of the heads to my AFRs? Maybe I'm not looking in the right places but I haven't been able to find anything on those heads.
I have the pressure tester on order, and it should be here tomorrow afternoon.
Just for fun I ran the numbers for exhaust backpressure effect on power. I assumed 4" bore, 3.75" stroke, 6000 RPM, and 10 psig. Multiply pressure by piston area to get the force on the piston (126lb), and multiply that by mean velocity (RPM / 2 * stroke * 8 * (unit conversion factors) = 125 ft/s) to get power in ft-lb/s, then divide by 550 to get 29hp. And that's a lower limit, because the backpressure will undoubtedly be reducing cylinder fill. Maybe not a super useful calculation at the moment, but I thought you guys might be interested.
I wish I could ramp up the timing a bit faster, but it is just not having any extra timing at 2800 and 3200. I keep trying to sneak a degree back in there, and every time I get KR. Now that my WOT VEs are pretty dialed-in, I might see if giving it more fuel there lets me give some timing.
Another possible issue is that AFR jumps around a lot during a single pull. Ignoring some outliers, it might be +/- 5% within a given pull. I've noticed my tach signal is pretty noisy in the datalogs. For example, I see two adjacent cells in a WOT pull where MPH went from 68 to 70, but RPM actually decreased from 5700 to 5650. In another, MPH goes from 66 to 67, but both cells report 5250 RPM and the same injector PW. Because PW is the same, it shows that the ECM is using this RPM to reference the VE value. I'd think it would use the time between dist ref pulses, but I guess not. If the ECM isn't seeing the right RPM for looking up the VE tables, my AFR is never going to be consistent. And +/- 5% is pretty significant: at a target lambda of 0.85, that's 0.81 to 0.89. Assuming stoich of 14.73, that would be a target of 12.5 and ranging from 11.9 to 13.1
Does this just come with the territory of old EFI cars, or is something up with mine? I've replaced the tach filter because the wire broke on the old one.
For the AFRs... again, seems a little much. I could see when targeting 12.5 12.3 to 12.8 but not that much I feel...
Don't you think a bad injector might have something to do with the A/F jumping around? You know cyl #1 temp is off.
Too much timing advance does nothing good. Your lower compression may tolerate more with pre-ignition but it still does no good. Your not on a dyno so you can't see power taper off but once power peaks there is no need to add more timing advance.
Like I said, I know 38° is past what's likely to make peak power. I'm just experimenting. It's currently fairly rich up there (lambda 0.83), which slows down the burn and requires more timing. After logging this tune, I'll pull back to a more reasonable advance (35° maybe?) and start pulling fuel. I think I've read these heads typically like lambda 0.85-0.88. I agree that a dyno is necessary to really dial in timing and mixture, but experimenting on the street is a lot cheaper than a dyno session.
As for diagnosis, I have a few ideas that don't involve pulling the intake. Obviously, a leakdown test would be good. Also, if I run it with the #1 injector disconnected and then with another injector on that bank (say #3) disconnected, the wideband should read the same in both cases once BLMs stabilize in closed loop. Oh, I just remembered - I pulled the driver side plugs a couple months ago and took pics. They look pretty crusty, but I'm not experienced enough to make any conclusions - I think maybe a hotter plug would be good, but that's not the current issue. What do you guys think?
I ran my impala there one night while we were on vacation at Natural Bridge. Nice laid back track.
It reads like you expect the computer/ECM to react a certain way. With bad/out of range inputs it gets stupid. I mean it maybe trying to chase it's tail and cycling inject pulse width and all injects on that bank. Only your data log knows how it reacts. Heck it may even change PW on the opposite bank too - it's just a machine that does what it's programmed to do.
