Why's my SuperRam so slow?
Once here he will have to have it inspected by DMV and a test only station nothing gets past them.
His cam/superram are good for now...his Cats will have to have the Ca EO# stamped on them too. Same as other cats but that stamp makes them $$. They are that strict!
Their machines dont know CI though....x2 on good #s without making the port big is where its at on a street car. The "hogging out" concept is 80s thinking.
PS - Yeah, you really need to figure out what's going on with that #1 cylinder! Something's wrong there.
Having said that, you DO have a manual car. Driveability with a 230/236 cam will not be a problem. (Fuel mileage, on the other hand...) If you want a high revving engine, you'd be better off blueprinting the engine - matching all the components to each other instead of using band-aids to make a high revving cam work with a torquer manifold.
Example: I bought a C5 that the guy had slapped a ginormous cam into an otherwise stock engine (234/246 on a 112 lsa). Just by having the heads ported and bumping compression form 10.5 to 11.5, I saw a gain of 30 peak hp and a 100 ft/lb gain in torque at 3500 rpm. Don't discount matching the compression to your cam.
I was just really hoping to save some cash by using the cam I have on hand. You're probably right though. I'll probably end up looking for something in the 220/230 range with maybe a 110 lsa. Definitely not looking for a high-revver!
That's a crazy gain. Is it possible that was mostly from the porting?
10 yrs ago my Elcos tags were around 50...now 197
Its the land of good weather and lots of fine women though.
Never used the Rhoads roller lifters but loved their old flat tappet lifters they tamed a big cam down once the oil got hot and did their job upstairs, going from std to them was noticeable.
Leakdown, compression, power balance, running compression should indicate the soundness.of engine.
Wallace Racing has calculators you can plug in all your drag strip data for calculated hp.
Unless a tuner shop is having dyno day.you want to sort out the cool cylinder first. No need to dyno with a known problem.
Thanks for the feedback on the Rhoads.
I've got a buddy with a leakdown tester that I plan to borrow as soon as he gets back in town. Forged pistons + headers is just such an annoying combo because it needs to be hot to leakdown/compression test, but there's no way of getting to the plugs without bumping up against the headers.
I *think* my buddy's got one of those. It's the getting the spark plug out and that in with a burning hot header 2" away that's difficult.
The 104-106 mph tells me that he's got ~300 NET chp. Maybe a tad more but not much.
I wonder if his cam timing is off?
I measured twice. The first time was pretty soon after a pull (~3min), and the second was a bit longer (~5-10min).
200 (1) (2) 260
340 (3) (4) 290
300 (5) (6) 300
270 (7) (8) 240
160 (1) (2) 250
280 (3) (4) 220
280 (5) (6) 240
260 (7) (8) 240
And my original, idle results:
160°C (1) (2) 280°C
285°C (3) (4) 240°C
250°C (5) (6) 290°C
245°C (7) (8) 230°C
I'm not 100% convinced there's an issue. The sooner I take the measurement after a pull, the less the differential between #1 and #2. It could just be that the alt fan is blowing enough air to cool the #1 primary down. I'll still swap the plug wire with a different cylinder to see what happens, but I'm not sure how much farther than that I want to go. Since the odd bank seems to be running richer than the even bank, the only malfunction that would make sense is a stuck open injector. The last time I had the intake off was to check for exactly that, and none of the injectors leaked fuel when I primed the pump. I suppose it could just flow a ton more than my other injectors, but I'd like to think Accel/Holley has better QC standards than that.
probably should go get my inspection sticker before I try that. Any suggestions on supporting the front Y-pipe with everything else disconnected? IIRC there's no hanger there. I suppose I could run open headers but that would mess up my O2 sensor readings (and be extra loud).
Engine should be warm regardless of piston type, prior to compression and Leakdown. Running compression is an indication of cylinder filling or valvetrain operation. How much air is getting in cylinder.
With forged pistons for the most part that has changed. There are lightweight racing piston that are loose in the hole until engine warms up. However modern forged pistons are designed for tighter clearances, providing quieter operation with less wear.
Gotcha, wasn't sure if the cat was in question or just running through a single 3" pipe period. Unfortunately, my cat is welded to the rear Y-pipe.
