ignition module
Old Nov 30, 2002 | 06:21 PM
Petros89's Avatar
Petros89
Default ignition module
I am upgrading my ignition system and will be getting a new ignition module.Should i get the stock one or something aftermarket?
Old Nov 30, 2002 | 10:12 PM
Petros89's Avatar
Petros89
Default Re: ignition module (Petros89)
ttt
Old Nov 30, 2002 | 11:37 PM
Speedracer176's Avatar
Speedracer176
the stock module will work fine with the low reving TPI motor.
Old Dec 3, 2002 | 02:09 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Since you are going to change it anyway...I'd go with the dynamod unit....from MAD or Corvette Central....or any of the other suppliers...at least thats what I did...Can't hurt anything..forgot to add ...it's 7 pin.....
tony
:smash: :smash:
[Modified by oldace84, 4:16 PM 12/3/2002]
Old Dec 5, 2002 | 10:07 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: ignition module (oldace84)
My idle seemed smoother after my DUI but I also put the stronger coil in and a few other things in at the same time so I can't really give you an answer that is anything more than speculation.
If you do wind up buying a DUI "Dyna mod" module I would buy it from Davis Ignitions direct for $49.95 instead of the $79.95 MAD sells it for...
My two cents.
Old Dec 6, 2002 | 07:20 AM
1SLO POK's Avatar
1SLO POK
Default Re: ignition module (Red 90 L98 Coupe)
is the ignition module the same thing as timing module, just worded different? :p:
Old Dec 7, 2002 | 07:58 PM
oldace84's Avatar
oldace84
Just a follow update...Did you buy the new module...DYNAMOD...from Mid America.....or what did you finally decide to do?????????????
thanks
tony
:confused: :confused: :confused: :confused:
[Modified by oldace84, 7:59 PM 12/7/2002]
Old Dec 8, 2002 | 12:45 AM
Petros89's Avatar
Petros89
It's on my xmas list but haven't desided.I see that holley and msd make them too.I will most likely call jeggs or summit and get what they have in stock
To ignition module
