Lt4 - Low compression numbers
Old Aug 21, 2020 | 03:23 PM
RandomTask's Avatar
RandomTask
Default Lt4 - Low compression numbers
Since I've built the motor, its had 155-160 psi across all cylinders. I've used multiple gauges to confirm. Dynos 315 to the wheels. From what I could find, I'm supposed to be in the 200+ range. Any ideas?
Old Aug 21, 2020 | 03:40 PM
Kevova's Avatar
Kevova
Cam or cam timing. I didn't see previous thread about your build. Miles on engine, since rebuild?
Old Aug 21, 2020 | 04:19 PM
RandomTask's Avatar
RandomTask
If it was off a tooth, wouldn't it run like crap though?
About 50 hours on the motor.
Old Aug 21, 2020 | 05:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
200 is a lot, whats done to the engine?
What makes you think it should be that high
150-160 is fine
Old Aug 21, 2020 | 05:59 PM
Kevova's Avatar
Kevova
Unknown cam 1 tooth, EFI won't like it. Cam with alot of overlap can have low cylinder pressure and be doggish at low speeds. 160 isn't terrible either, depending on static compression ratio.
Old Aug 21, 2020 | 06:01 PM
ChumpVette's Avatar
ChumpVette
I would expect 175-180.
Old Aug 21, 2020 | 09:01 PM
C409's Avatar
C409
..... There are a LOT of things that can affect cranking compression readings ... what you really want to see is that ALL cylinders read about the same ... there are also a LOT of things that affect chassis dyno readings too ! .....
Old Aug 21, 2020 | 09:20 PM
RandomTask's Avatar
RandomTask
It's stock lt4 (except .030 over) except for some ARP stuff.
Old Aug 21, 2020 | 09:51 PM
Kevova's Avatar
Kevova
Stock 330 horsepower and 315 at the tire. Sounds good to.me.
Old Aug 22, 2020 | 07:33 PM
mtwoolford's Avatar
mtwoolford
An LT4 cam has a lot of overlap; enough to eliminate the need for an EGR system. That will affect your compression numbers.
Old Aug 22, 2020 | 09:01 PM
MatthewMiller's Avatar
MatthewMiller
All good points. Yeah, we'd expect the LT4 to have a bit less cranking compression (dynamic compression ratio, essentially) because of the extra overlap as mtwoolford mentioned. If that's an honest 315rwhp on a Dynojet, then your engine is running really strong. No issues.
To Lt4 - Low compression numbers
