Head lights
Old Aug 28, 2020 | 06:57 PM
mickflstc1's Avatar
mickflstc1
Default Head lights
Can someone explain why when I turn on the head lights they make a clicking noise for a few seconds then it quits same thing happens when you turn them off. I have looked and the manual over ride kizzmo top **** is turning back and forth on both adjusters. Help
Old Aug 28, 2020 | 07:57 PM
s carter's Avatar
s carter
Are you saying when you turn on the motors run but no movement or they will turn and operate and then continue to for a few moments, if so it sounds like the bushings in the actuators have broken down.
. Go to you tube search for C-4 corvette head light motor watch a few of your choice
Old Aug 28, 2020 | 08:14 PM
mickflstc1's Avatar
mickflstc1
Default Head light
The head lights function fine but there’s this clicking noise that continues before and after
Old Aug 28, 2020 | 08:38 PM
s carter's Avatar
s carter
Bushings have self destructed, if you're moderately handy with tools and taking things apart you can do it in about 45 minutes a side again You Tube and questions here. In some very rare instances the drive hub in some actuators have been becoming loose on the shaft so when your inside make sure the is no movement between aluminum Hub a shaft.
https://corvetteparts.com/item/dowel...ings-1988-1996
what year is the car?
To Head lights
