Clutch, Trans, or something else...
Old Sep 7, 2020 | 08:10 PM
84 4+3's Avatar
84 4+3
Default Clutch, Trans, or something else...
Had a weird incident driving home today. Left a light and got on it a little. Car felt fine. Grabbed second and thought I missed it. I look down and sure enough I'm in it. Ease into gas and it has power but feels like I am driving with a loose converter. Flairs up 1000 rpms or so then starts to drop down. I limp it the 5 miles home. Checking Overdrive it seems to kick in like normal.
Fast forward to my driveway and it slopes uphill. I park at the end nose up and dump the clutch in first. Car stays running and barely rolls or bucks. Then starts bucking and dies. Okay. Now this whole time the clutch pedal feels... Well weird to me. I let it cool for half an hour, spray a little water on the bell housing whatever. Come back out, go down the street and everything feels normal. I went maybe a quarter mile and just parked it in the garage.
So it has a new clutch, flywheel, master and slave cylinder. I can only think of 3 things wrong, clutch hydraulics got heated and were hanging up. Clutch itself overheated and was slipping bad. (had no smell though) or something internal in the trans or overdrive. I think the last is unlikely as I don't think cooling would change anything... Just wondering what your thoughts are. Glad this happened on the street instead of a dyno or major highway or something. All backroads kept me safe lol.
Old Sep 7, 2020 | 09:30 PM
MatthewMiller's Avatar
MatthewMiller
I don't think it's clutch hydros, because the default mode for a clutch is to be full engaged. The hydraulic release system's failure mode is usually the opposite: they don't fully release the clutch when you press the pedal down.
Old Sep 7, 2020 | 09:32 PM
84 4+3's Avatar
84 4+3
Originally Posted by ihatebarkingdogs
How is Reverse? Does the car back up normally? I assume this is a 4+3 transmission?
reverse is fine as is engine braking. When it happened reverse behaved the same. Yes, 4+3. Should have clarified.
after I let it cool it returned to normal too. Clutch seemed to bite higher up in the pedal before allowing to cool.
Old Sep 7, 2020 | 10:23 PM
jv9999's Avatar
jv9999
How many miles on the clutch and trans? Smell anything burning? Been servicing the OD unit every 10K or so? Any odd noises?
Old Sep 8, 2020 | 08:13 AM
84 4+3's Avatar
84 4+3
Less than 3k on rebuilt everything minus the 4 speed side of the trans. Nothing unusual other than a bit of throwout bearing noise. Anything quiet i won't hear however...
True. Do you think if the slave got too hot it could be hanging up in its bore? The pedal feel completely changed when this happened. Maybe pressure plate...
Old Sep 8, 2020 | 10:12 AM
MatthewMiller
As in, maybe it's not returning all the way back after you let the clutch pedal out? It's possible, I suppose. I was going to suggest that the pressure plate spring (is it diaphragm on those? not sure) might be doing something funky. The thing is, either of these explanations assumes that the fundamental problem is the clutch slipping. I would have thought you would smell it burning as much as you were "on it" when this first occurred. But maybe not. I can't think of anything that would give the clutch pedal a strange feel and disconnect the engine from the drive wheels in the way you describe that did not involve the clutch slipping.
Old Sep 8, 2020 | 10:48 AM
84 4+3's Avatar
84 4+3
its a traditional sprung pressure plate like in all sbcs. And my thought was od clutch pack but in direct drive that only does engine braking as the sprag and planetary otherwise run... I think. The slip was kind of chattering in the driveway. If I dumped the clutch engine off it grabbed slipped and grabbed. Kind of like it was uneven... wonder if I glazed it. Thing is I wasn't on it that hard. I topped out first but wasn't matted or anything. Like half throttle and didn't wail into second. I had earlier and it felt fine. The only thing I could think is that I was in traffic and something got hot... but why did first run out fine and second screw up? I may pull the inspection plate this weekend.
Old Sep 8, 2020 | 12:33 PM
84 4+3's Avatar
84 4+3
By "topped out" do you mean that you had 'high' RPM when you shifted into 2nd? If = yes, I think the pressure plate hung up from centrifugal forces. I had it happen with a Borg and Beck 3-finger pressure plate in one of my early cars I had in High School (late 60s). I've heard of centrifugal-release occurring with diaphragm clutches, but it has never happened to me.
If it does it again, or begins to do it frequently, and high RPM is the factor causing it, the pressure plate will need to be replaced. Diaphragm spring pressure plates are susceptible to being bent or distorted during installation if the bolts aren't very carefully, incrementally, tightened. If it got distorted during installation, this behavior at high RPM could be a result. Another possibility is that some bit of material broke off and lodged in the pressure plate not allowing it to engage.
I'm with Matthew Miller: If it was slipping, you should have smelled it on the way to the house. Unless the friction material is non-organic, ie metallic. In that case it would just smell "hot".
My guess is that you will be taking the clutch apart for inspection. Something went wrong.
yea. About 6000 rpms. I think its organic ceramic... mcleod 75225. I agree... I just smelled hot mostly.
I was very careful installing. Star pattern 1 turn each bolt until tight then torqued to spec...
Old Sep 8, 2020 | 03:55 PM
84 4+3's Avatar
84 4+3
I don't use a star pattern on clutch pressure plates. I feel that the pressure plate is distorted less by going around it rather than back and forth across the entire diameter of it with the "star pattern". I go around every-other bolt 1/2 turn for the first three, then go to the other three and 1/2 turn every other bolt. Repeat until tight-ish, and torque to final. Think of it as a 'spiral-down' instead of a rocking back and forth. With the spiral the next bolt tightened is only a few inches from the one with the most load on it (the one you just did). With the star pattern, the next bolt tightened is almost straight across from the last bolt tightened. The load is transmitted across the entire cover, not just the few inches of the same side.
I was curious as to what the FSM says, so I looked in my 85 FSM:
"Install a bolt in every hole and tighten down evenly and gradually until tight to avoid possible clutch distortion. (Cover loads are as high as 1-1/4 tons.)" So the FSM doesn't get very specific either.
I doubt these parts are delicate enough to be sensitive to what bolt pattern is used to tighten them is as long as the bolts aren't just rammed down with an impact. I think some little bit of something broke off and got lodged in it. I think it will be obvious what happened when you take it apart and conduct a CVI. (Close Visual Inspection).
I just thought about it... the inspection plate is behind the flex plate... may have to pull the trans instead....
Old Sep 8, 2020 | 05:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I had a clutch in a Camaro that did a similar thing: I launched it at the drag track (on street tires so by "launch", I'm talking 2.0x, 60'), hit 2nd with a flat foot shift and something "let loose". I babied the car back to the pits and began trying to assess what went wrong. By then, it seemed fine, so I staged again, and on the launch it was as if the clutch wasn't hooking. I was like slipping....but jerky and rough. Weird. I got out of it right away and babied it down the track, back to the pits. Loaded it up and headed home. I made it about 1/2 way home and she let go all the way. I coasted off the hwy, into a parking lot and called for a ride. Later, Picked it up w/a trailer, took it home and pulled it apart.
The verdict? The splined/hub part of the clutch disk had ripped out of the outer part of the hub and was spinning somewhat freely inside the outer hub. I'd guess that initially, it tore apart, and then caught on the roughly torn metal "spokes"...and that is why I was able to drive it again. IDK why it let loose for good, driving home on the highway....but it did. I needed a new disk.
Old Sep 8, 2020 | 05:06 PM
84 4+3's Avatar
84 4+3
So you're saying clutch dump and see what happens? I'm game.
Old Sep 8, 2020 | 07:28 PM
84 4+3's Avatar
84 4+3
Update. Did a hard launch. Now I smell it. Sounded fantastic and as it slipped it bit harder though... which was weird.
Old Sep 8, 2020 | 07:58 PM
84 4+3's Avatar
84 4+3
Update 2: now that it got hot its behaving normal?
Hit it again and resulted with this...
Hard to see but there is about 100 feet of 2wheel peel... I dont get it...
Old Sep 8, 2020 | 09:36 PM
MatthewMiller
That happened to me at an out-of-town autocross with Danny Popp riding shotgun. But mine let go suddenly and completely and never pretended to work again. I know what you mean though - when removed from the car it took a lot more than just hand pressure to spin the hub inside the disk. Based on the most recent posts by the OP, though, I really doubt you could lay down black strips if the hub were broken in the disk.
84 4+3, to me the big wild card in this equation is that overdrive clutch. After watching
, I now understand why IHBD was asking how the car feels in reverse. Does the problem feel the same when the car is in OD vs not? There are the clutch packs in there to worry about as well as that front bearing that can disintegrate if it's installed with too much preload. That said, none of this would explain the weird pedal feel.
Old Sep 8, 2020 | 09:44 PM
84 4+3's Avatar
84 4+3
84 4+3, to me the big wild card in this equation is that overdrive clutch. After watching this video, I now understand why IHBD was asking how the car feels in reverse. Does the problem feel the same when the car is in OD vs not? There are the clutch packs in there to worry about as well as that front bearing that can disintegrate if it's installed with too much preload. That said, none of this would explain the weird pedal feel.
Reverse, OD on vs off feels exactly the same... od slipped a little more but it was lower rpms. Did that direct drive too. Reiterating: slip was more noticeable heavy load lower rpms vs lighter load and more rpm.
But I can still very clearly smell clutch. Clear as day. Could my new slave cylinder be effed?
Old Sep 8, 2020 | 11:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^Good call on the clutch material coming off the disk. I've had that happen too.
Old Sep 9, 2020 | 09:32 AM
84 4+3's Avatar
84 4+3
With Sunday back to my only day off it'll be a few weeks before I have time to pull it lol.
To Clutch, Trans, or something else...
Old Oct 22, 2020 | 09:39 AM
InfomanSS's Avatar
InfomanSS
Any updates, 84 4+3? I was planning on getting the same clutch kit, so you have my attention. :-)
Old Oct 22, 2020 | 10:07 AM
84 4+3's Avatar
84 4+3
I've been beating the snot out of it the last couple days and it seems fine.
Old Oct 22, 2020 | 06:18 PM
InfomanSS's Avatar
InfomanSS
Maybe the theory on some material coming loose was true and now that piece has been worn down or is out of the way and you are back to the majority of the disc engaging the flywheel. Roll with it, I guess?
