slave cylinder
Old Dec 2, 2002 | 09:07 AM
devilfish's Avatar
devilfish
Default slave cylinder
the pin on the slave cylinder ( zf ). Has annyone needed to get a longer one? And why? After I got my FW machined ( yes i know ) i got some freeplay between the slavecylinder pin and the clutch fork. So I got a tapping sound when braking hard or turn hard. I think its combintaion of machined FW and wear on the fork and pivot ball.
Regards
Old Dec 3, 2002 | 07:44 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: slave cylinder (devilfish)
A TTT for you...:)
No freeplay here but I went with a new throwout bearing and clutch fork when I did my clutch change/flywheeel conversion (I had to cut the fork to get the bellhousing off the car.... :eek: ).
Anyone else?
Old Dec 3, 2002 | 12:58 PM
devilfish's Avatar
devilfish
Default Re: slave cylinder (Red 90 L98 Coupe)
ok thanks for the TTT :)
Mayby I just can have a pin made for me, that is littel longer
To slave cylinder
