LED Headlights
Old Sep 10, 2020 | 09:57 AM
pherr's Avatar
pherr
Default LED Headlights
I am wanting to upgrade to LED headlights. I thought I would check to see if anyone has used either of my choices. I am considering either JW Speaker 8900 or 8910 (8910 is a little better but is more expensive). Or, Headlight Experts H6054 LED conversions. Both seem good but, the one from Headlight Experts does not list the low beam and high beam output separately so I am on the fence with that one. Let me know if you have done and LED conversion and the results. Thanks
Old Sep 10, 2020 | 10:36 AM
Whaleman's Avatar
Whaleman
I have the JW Speaker's and love them. Don't remember the number. Dan
Old Sep 10, 2020 | 10:37 AM
aklim's Avatar
aklim
I have done a Genssi set with some resistor modules inline. Didn't want to cut and splice so I got the modules and can return it back to stock if I were to sell the car ore salvage what I can before scrapping it.
Old Sep 10, 2020 | 10:38 AM
vader86's Avatar
vader86
I'm using Gennsi 7x6 projector lights from Amazon.
Old Sep 10, 2020 | 10:42 AM
Whaleman's Avatar
Whaleman
Just checked mine are 8900. Dan
Old Sep 10, 2020 | 10:48 AM
aklim's Avatar
aklim
Headlights
Resistor
Old Sep 10, 2020 | 11:12 AM
Nomake Wan's Avatar
Nomake Wan
https://www.corvetteforum.com/forums...on-how-to.html
Here's my write-up on doing an LED conversion for my '95. I used a set of headlights off Amazon and love them; way better than the stock halogens, especially with regards to lighting up reflectors and signs on the road.
Please don't use resistors with LEDs if you can avoid it. It defeats the entire point of going to LEDs, and as I've shown, there's absolutely no need to use them on a C4.
Old Sep 10, 2020 | 12:14 PM
ZWILDZR1's Avatar
ZWILDZR1
I have been looking at various different options for my cars headlights. I want a headlight that is a direct plug in and lite in weight. The car gets driven mostly during the day. Just yesterday we were out and the sun went down. I was wishing for a set of better lights.
Old Sep 11, 2020 | 09:31 AM
pherr's Avatar
pherr
Great write-up Nomake Wan. How do you like the headlights. I am a bit unsure with there being a lot of cheap LED headlights and quality is not always there. That is why I was looking at the ones I was.
Old Sep 11, 2020 | 01:03 PM
pherr's Avatar
pherr
Dan, did you have any problems with the install? Also, did you have any issues with the fog lights or high beam indicator that others have had?
Old Sep 11, 2020 | 01:36 PM
Whaleman's Avatar
Whaleman
Easy to install and I used the plug and play resister unit. Only need on one side but you have to buy two. I already gave away my extra one. Dan
Old Sep 11, 2020 | 01:46 PM
aklim's Avatar
aklim
Odd. Only way I can get it to work is use BOTH units. Either side alone DID NOT work
Old Sep 11, 2020 | 02:44 PM
pherr's Avatar
pherr
I believe this is due to the ground that Nomake Wan talked about in his write up. I am looking at the wiring diagram now to work out a solution that will allow the operations of the fog light as intended. Although, since I may use the fog lights as DRL I may use the solution that Nomake Wan did but I think there is a clearer way.
Old Sep 11, 2020 | 07:25 PM
50kmsec's Avatar
50kmsec
Did the led lights on mine and loved it BIG difference. Just one price level below the JW don't remember the number but worth every penny. Also did the interior LED lights another BIG difference
Old Sep 11, 2020 | 11:25 PM
Nomake Wan's Avatar
Nomake Wan
I have no complaints so far. They work great, have good beam patterns, and make it a lot easier to see at night. It was really surprising when I went to drive my dad's '94, flicked the headlights on, and was like...wow why can't I see--oh right, halogens. I'll be converting his over to LED soon.
And the resistor thing, as you concluded, is to try to get around the weird circuit design GM had for the fog lights and turn signals. Don't use resistors, they're literally a waste of both money and current and generate unnecessary heat. The C4 doesn't have a canbus that checks resistance values of bulbs, nor does it have a way to check for dead bulbs, so there's absolutely zero reason to use a resistor anywhere on the car when converting to LEDs. You simply have to make sure you switch both the turn signal flasher and the hazard flasher over to solid-state LED flashers, and make sure you modify the fog light relay's ground so that it connects to a real ground rather than the high beams. Or, as you stated, find a creative way to emulate the factory function using some sort of external circuit (perhaps a second relay that energizes when the high beams are powered on, and connect to ground when energized?).
Old Sep 11, 2020 | 11:46 PM
-=Jeff=-'s Avatar
-=Jeff=-
I am using Sylvania 69822 Nighthawk LEDs very happy with them. I also chose the path of no resistor as I wanted lower load benefit. So I added a relay instead and the lights work like stock. Using Beamtech 880 bulbs for the fog lights
Old Sep 12, 2020 | 08:07 PM
pherr's Avatar
pherr
Nomaker Wan, no I am not going to use resistors. I do have one question in your solution can you turn the fog lights on without the lights? I am thinking of doing one of two circuits to solve the issue.
1. Add a relay into the current circuit. This would keep the current mode of operation and get around the ground issue.
2. Since I am thinking of using the fog lights as DRL. Build a circuit that would turn the fog lights on with the ignition, than when the lights are turned on they would operate as normal. Turning off with the switch or with the high beams.
3. Use your solution.
I am working toward #2 but I think I may use #1 as a interim solution. Thanks everyone for the replies. Nomake Wan I did go with the same headlights you did, different fog lights though. I really liked the JW Speaker 8900 but at almost $200 a side I did not think the value was there.
To LED Headlights
Old Sep 14, 2020 | 02:53 AM
Nomake Wan's Avatar
Nomake Wan
The problem with #2 is that the fog light switch is a latching switch, not a momentary switch. Doing the relay (#1) or grounding the fog light relay (#3) is a far better idea.
Old Sep 14, 2020 | 10:37 AM
pherr's Avatar
pherr
I did get the headlights installed. I bought the same ones. For now I grounded the fog light relay separately from the headlight high/low switch. I did not splice it I just replaced the pin on the relay housing until I make further changes. For the DRL on #2 of my plan. What I am thinking about is using relay. The coil will get power when the ignition come on. Pin 30 would get power from the headlight switch. On the switch there is a wire (white I think) that has 12v when the headlights are off, 0v when on. I would then feed pin 87 to the foglight relay, turning on the foglights. When the headlights or park lights are turned on that pin on the headlight switch will go to 0v so now the foglight will operate as normal, with the foglight switch. When you turn the headlights off, 12v, foglights come one. I may consider putting a switch to override the DRL function, hidden somewhere maybe the glove box. If I do this I will also add a relay to put the function of the foglights to the factory intent (turning them off when the high beams are on.) The one thing I need to verify is that the pin I want to use on the headlight switch goes to 0v with just the park lights. What do you think.
Old Sep 14, 2020 | 11:51 AM
Nomake Wan's Avatar
Nomake Wan
I think I wouldn't go through the trouble personally, but if you want to give it a shot, go for it! I love experimentation, so it would be a fun exercise regardless.
